Liking the finish of the cam cover etc, very classy.
Good to see you're focusing your energy into something positive - going to be one very well built westy when yoy have finished.
Thanks Pete - doing the best I can :yes:
Pic of what the offending bush should look like, you can see how it splits length ways to clip in the tube.
This is actually a column mount for a LHD car but it gives you the idea. No idea why I had one of these in my kit :d
They look very similar to the old BMC steering column bushes after they upgraded from the felt ones.
cheers Mark :t-up: I'll fire an email off the Westfild as I'm sure I have got anything like that. I only have the outer metal bracket itself, none of the inside parts :oops:
Doh! I froze mine to get the stupid thing to fit :d
  • 2 weeks later...
Update time :laugh:
Radiator fitted, using rubber bobbins to avoid being solidly mounted
Pair of horns also fitted - see above pic. One high pitch, one low.
Dashboard wiring completed after getting hold of another connect and some 5mm spade terminals for the switch illumination/ground
New gaiter/seal thingy and gear stick fitted. Some doughnut put too much oil in the turret :cry:  :d
Differential filled with oil
Gearbox filled with oil
Brakes bled - thanks Bernie :t-up:
Rad fan fitted
New oil filler cap and a breather filter fitted
Cooling system almost complete, just need to run a line for header tank bleed to rad. Deciding how best to do this. Also need to fit couple of p-clips
Blanking thingy's fitted to inlet manifold to blank off unrequired take offs
Intake pipe went to the welder yesterday to have a take off for the idle air control valve and threaded boss for the air temp sensor welded on
will go somewhere about here
Trigger wheel fitted to crank pulley. Also checked the timing whilst I was at it and all was well
Need to make up a bracket to fit the crank position sensor. Need to think about this a bit
Need to have a tidy up :down:  :laugh:
Doesn't it all look so nice before it's been driven a few thousand miles.
Took delivery of one of these in the week, can it be installed on its side?
Good progress mate :t-up: nice shiny looking intake pipe too :cool:
Cheers mate - will be going for engine start soon :oops:
Whats left to do.....
Fit injectors/fuel rail when they come back from blink for cleaning - waiting on some seals
Finish cooling system - may run a hard line down to RHS (when in car) of engine bay
Make a bracket for crank position sensor
Clean, paint and fit idle air control valve and throttle body
Fit intake pipe and air filter
Take off sump to check I've not squashed the oil pick up mesh
Battery
Wiring wiring and more wiring :down:  :laugh:
Calibrate sensors and get a base map from Omex
Temp fit mx5 exhaust manifold if new one hasn't arrived from Westfield
Not a toooooo long of a list - but not far away :t-up:
Does this not risk drawing in unmetered air into the inlet manifold via the cam cover? Oil cap looks good!
If the battery is a gel type then yes it can be mounted any way, side upside down or rightway up.
Erm don't know :o Anyone?
Thanks Norm :yes:
