How weird, there are some fantastic looking paint/powder coat jobs in there, but what's with the obsession for swapping the characterful original style valve cover for the identikit "square and finned" jobs that look like the dressed up standard rot box covers you get on the "sports" models of Boggs standard family cars.
The cam cover from the US Escort GT, mazda protege and 323gtx which also fit the mx5 engine don't have the top of the cam belt cover as an integral part of the cam cover, and thus allow you to do a cam belt change without having to remove the cover or break the seal of the gasket.
I as other are also doing have taken the angle grinder to the front the mx5 cover to run exposed cam gears which then makes for quick and easy belt changes as well as better visibilty for checking the belt.
And letting the stones in Mark.
And back out again just as easily.
You willing to demonstrate to me?
i have been for the last 8000 miles :d
I know of three XE's taken out by stones trapped by belt guards :p
:d
I was thinking of you chucking a stone or two into the open cam belt area and see if they come out again :d
The thought occurred to me today that I may have made a dangler up with my fuel sender unit :(
I installed as per the build manual with the height from the top of the unit to the bottom of the float as instructed and then cut off the excess float arm.
I have the long range fuel take and the float I guess will stop before the tank is empty. Therefore reading empty when there is plenty of fuel left.
Does anyone know what the measurement from the top of the sender to the bottom of the float on a long range should be?
The sender in my standard tank came pre fitted by the factory and already set at the correct length. I don't have the measurement for the long range tank, but i suspect that if you're sender was already fitted in the tank then it started off correct.
So I "fixed" something that didn't did fixing :)
The manual shows taking it out so assumed it needed to be done. Should have thought about the long range bit at the time! Hopefully I'll be able to source a new float arm from somewhere as the while unit is £50 from Westfield
Look at things positively, at least you'll know that when the gauge is showing empty they'll still be enough fuel in the tank to get you home :oops:
Is the float arm not just a length of stiff wire with a couple of bends? And if so can it not be replaced with the same but slightly longer?
Yeah - will take it out and see how it us secured at the float end. If it's simple will source a bit if wire and make something up :)
  • 2 months later...
Time to bring this thread back alive!!!!
Those of you who "know me" will know I've had a change of circumstances which resulted in the build going on the back burner :(
I now want to give myself something to focus on in my spare time so the project seems the ideal thing. Things will move slower than I thought as things will have to be paid for as and when funds allow.
So give me your best motivational kick up the backside :)
I aim to go in the garage and make a list of things to tackle. I've somewhat lost track of where i was :p
Good luck Dave, just plod on and complete one job at a time. You get to the finish line just the same, but more orderly.
Well done mate :t-up: I'm just up the road whenever you need tools, advice or a helping hand.
Lets see if you can finish before I get my Narrow done :oops:
