What no video of it :d :d
Looks like you could have done with pruning the conifer first before you started :oops:
Lol Mark!!
Judging by the amount of oil on the top of the bellhousing It looks like it's been leeking quite badly from the rear which makes be think that the oil above the starter motor and under the exhaust manifold has all come from the CAS oil seal.
I know from experience that the air movement in an engine bay can do funny things and spread the oil over everything and to the places you'd least expect.
I think you're right mark, here's some picks from a further distance
looks like its come out of the cam sensor housing and run down onto the top of the block towards the front of the engine, and also down onto the bellhousing and down either side of the block.
What's your advice? Replace as per your link, install in the westfield and see what happens?
That's what I'd do, It's only a single bolt to remove it to change to o-ring. A smear of oil on the new seal will help it slide back in again. The hardest bit is aligning it to go back into the slot in the cam.
Also have a look at the other seals mentioned a few weeks ago and the clutch spigot bearing, as doing them now will save a lot of work later.
I'd suggest then giving everything a good degrease and clean as it helps to spot any leaks later on (over cleaner works really well), drop it into the westfield and see what happens.
I'd suggest then giving everything a good degrease and clean (over cleaner works really well), drop it into the westfield and see what happens.
These are on the list of things to to :yes: :yes:
Don't forget to label everything on that look as you pull it out
There's tape on everything :d
Got the wiring loom out today. it's going to be fun sorting that out :(
How you'll look back and laugh about how much fun it is sorting out the looms....those long winter evenings will just fly by.... :laugh:
Daves hoping this will be sorted well before then, with a little help from his new found friends, "Essex Boys"
I've stripped 3 of those looms now :bangshead: It doesn't get any easier and certainly no quicker :arse: but there's a lot of weight to be saved and it makes fault finding much easier once all the surpurfluous circuits are gone.
Isn't tomorrow the big day for the Westfield visit ? If so, have fun :cool:
it is indeed :d I'm preying it doesn't rain!
Enjoy, hope it stays clear for you to get a test drive.
10 Pages long and you're not even at the test drive yet :laugh:
Is this a record?
Hope you have a great day.
