Andrew Posted December 1, 2019 Posted December 1, 2019 ISS passing over at 16:37 approaching from SW if anyone's interested. Visible for about 6mins.. Looks clear here. 2 Quote
Geoffrey Carter (Buttercup) Posted December 1, 2019 Posted December 1, 2019 I often watch it going over when its forecast. Still as exciting as the first time I watched it go over. Quote
TableLeg Posted December 1, 2019 Posted December 1, 2019 Indeed the ISS app is amazing. Watching the sun break over the earth surface is incredible. 1 Quote
Geoffrey Carter (Buttercup) Posted December 1, 2019 Posted December 1, 2019 Just watched it fly over. Very bright and very clear. 1 Quote
wizzer Posted December 1, 2019 Posted December 1, 2019 Think that was it ,it was fairly shifting 2 Quote
Andrew Posted December 1, 2019 Author Posted December 1, 2019 16 minutes ago, Geoffrey (Buttercup) - North Yorkshire AO said: Just watched it fly over. Very bright and very clear. Well I looked and looked but didn't see.. There's a bit of high cloud that may be obscuring it. Will have another look when it's back round again shortly at 6:13 pm 1 Quote
Mole Posted December 1, 2019 Posted December 1, 2019 I had not seen it before so Andrew pleased to see your post and a heads up!! I thought I saw it but just turned out to be lots of bright stars .. and then a plane on its way to Amsterdam!!! Having seen Wizzers photograph.. I definitely did not see that!! Quote
wizzer Posted December 1, 2019 Posted December 1, 2019 6 minutes ago, Mole said: I had not seen it before so Andrew pleased to see your post and a heads up!! I thought I saw it but just turned out to be lots of bright stars .. and then a plane on its way to Amsterdam!!! Having seen Wizzers photograph.. I definitely did not see that!! Have another look when it comes back past, I've never seen it before it couldn't have been a plane it was moving to fast and no vapor trail Thanks Andrew Quote
Jude - The Mad Widow Posted December 1, 2019 Posted December 1, 2019 What app is it that tells you about astronomical events? I used to have it but now cant remember? Quote
Geoffrey Carter (Buttercup) Posted December 1, 2019 Posted December 1, 2019 4 minutes ago, Jude - The Mad Widow said: What app is it that tells you about astronomical events? I used to have it but now cant remember? Spot the station & Heavens-Above are two I use Quote
Jude - The Mad Widow Posted December 1, 2019 Posted December 1, 2019 @Geoffrey (Buttercup) - North Yorkshire AO thank G, downloaded Heavens above. Its a beautiful night for it tonight! Quote
Andrew Posted December 1, 2019 Author Posted December 1, 2019 Spotted it this time round.. hard to miss really. 20sec exposure.. must try harder. 3 Quote
marcusb Posted December 1, 2019 Posted December 1, 2019 ISS spotter app is quite good, free and gives current live position and forecast for your location Quote
Paul Hurdsfield - Joint Manchester AO Posted December 1, 2019 Posted December 1, 2019 If you go on the NASA website, register and put in your location you will get email updates of when it will be visible over you, twice tonight, the early one it was a bit light so it was hard to spot, the later one was clear as a bell, but I'm used to it, I know where to look and what to look for My eight year old grandson stayed over last night and I was able to point it out to him. Quote
pistonbroke Posted December 2, 2019 Posted December 2, 2019 Took this tonight with me new £4.99 camera from Lidle 1 Quote
