Barney, I used to think that big was beautifull.
Now small and light is the way to go.
Still you and John are the right height. :D
But they can't stand next to each other. They generate too much of a gravity well... :oops:
  • Replies 68
  • Blatman
    11
  • Matt Seabrook
    7
  • Annie
    6
  • tex
    4
Back to the topic for a minute, just a thought ......
...assuming you've got a flat floor as well as a diffuser, should the diffuser have a hole in the rear "flip up", so that air coming in from the nose cone > engine bay > transmission tunnel can exit un hindered out the back of the car, or will it find its own way out via the wheel arches ? ???
SPM
QUOTE
But are you a 32" waist Barney
I bet he used to be..... when he was 13  :laugh:  :p
and before you point the finger back at me i'm well on the way to getting back to that myself  ;)  i just need to get off what Xmas has put on  :arse:  :bangshead:  :D
Air from the transmission tunnel will bleed off over the sides of the diffuser and out in to the wheel arches (and anywhere else there is a gap), 'cos there's no way to seal them. Another reason why they don't do what they look like they should do...
They do look good though. Apart from keeping the diff cleaner the do add weight ;)
True. My diffuser weighs about the same as a pair of damp socks...
I was young and impetuous back in those days...
About 3-5kg I would guess at. Some people pay a lot of money to save that :D
Not even close. My diffuser weighs less than a kilo, and that includes all the attached fitting hardware. It's a proper, pre-preg nomex honeycomb Mickmade item ;):cool:
i made mine from 1.2mm ally sheet - weighs very little
but has good uses  :D  ??? ketley!!!!!!!  :arse:
Photobucket
Ah! Does it work though (no offence mhc) or is it just for bling ???  :p  :D
Tubs.
Bling :D unless you want to keep the diff clean.
PlaysKool
Diffuser
Fibre-glass rear diffuser measuring 105cm wide by 82cm long and 16cm high at the rear.
These are made in gloss black and have a woven matt finish, producing a strong product. These weigh 3.5kg.
Stange that the carbon one should be more than 3.5 times lighter than a GRP one
can't remember where, but i did see one made out of 6mm plywood recently!
