Att VX owners  !!!!!
Hooray.......home time. Play nice 'til I get back........  :D
  • Replies 192
  • Matt Seabrook
    26
  • mb893
    22
  • Blatman
    20
  • scruffythefirst
    14
Two words my friend.
Atmo Cosworth.
Tunned Pinto and tooo heavy
Don't you start.......  :D
:oops: oh bl**** hell Paul :D
You missing a vital piece of your cossie arent you Mr B ???
Scruffy
No all 160 kg's of it is there  :D  :D  :p
9 page thread and nobody has stated the obvious.
X-Flow owners dont need to brag about their engines potential. More than enough usable power,cheap,reliable and plenty of bits around. Henry knew what he was doing when he introduced this marvel of automotive engineering. :love:  :love:  :love:   :D
Yup, he'd found a way to triple the sales of oil :D:D:D
Scruffy
F 16's and f15's and X-flows have the same oil system
Total loss oil system   i.e. you refill the oil at the same time you refill the fuel tank.
Scruffy
"Yawns"......that old cliche again  :D This minor design flaw is more than compensated by the overall excellence of the total package :love:  :D  :cool: Besides,look at the advantages...rust free underside and axle casing! :D  :D  :down:
Cost you more in oil over a year than it would to tune a zetec, and thats bl**** expensive (to get to vx or cossie power levels at least)
Scruffy
I'll say sorry in advance (sorry), but a nearly sensible question needs to be asked here...
How much money would it take to get any 4 pot car engine to
( A ) 150bhp/ltr?
( B ) 230bhp/ltr?
( C ) 270bhp/ltr?
I really would appreciate some serious answers on this... not actually axe grinding at the mo :D
And I'd just like to add that SteveD's eloquent and charming relpy fully meets his usual exacting standard of objective discourse - keep up the good work that man! :D  :D  :D  :D  :D  :D  :D
John
Probably best letting the 16 valve boys carry on with the p******** contest without getting involved mate  :D  :D  :D
Just sit back and think smug thourghts  :D  :D  :D  :D
Perhaps we should invent a new formula for working out which is the best engine and find out which is the most fun in a westy.
Oh hang on they all are arn't they   :D
Now you're just being maliciously reasonable aren't you. :D  :D  :D
John
( A ) 150bhp/ltr?
( B ) 230bhp/ltr?
( C ) 270bhp/ltr?
- 150bhp - potentially very easy and cheap for most 16v engines.  A stock 2.0 VX with the standard injection will produce 150bhp and a Zetec on carbs should be able to do that too.
- 230bhp - starting to depend on the engine now, because this is getting into the realms of cam changes, maybe some work on the head, pocketing pistons (hence engine strip down), etc.  I'm also assuming at this point that carbs and standard fuel injection set ups have been thrown in the bin and throbble botties and a mappable ECU are required.
Best guesstimate - 3.5-5K
- 270bhp - possibly not that much more than 230bhp, although again some engines may need more head work than others which can be time consuming.  You'd probably need different cams and, depending on the revs needed, standard rods / pistons might be marginal.  Other than that, you'd have bought most of the kit to get the engine to 230bhp so there's not really a great deal of difference.
Best guesstimate - 1K on top of 230bhp amount.
NB these guesstimates don't include things like exhaust systems, air filters, plumbing, dry sump systems, etc.  It's purely to build the basic engine.  Actuall installation costs will, most likely, be somewhat higher by the time you fire the engine up for the first time. But then, for example, a 2.5K Busa engine isn't just a plug and play option and will require additional items like a dry sump system, exhaust, mixture tweakage ?, prop-shafts, etc.
