Remeber to think about packing the diff down a bit Darve when you put it in, stops the CV boots rubbing later on
I saw your post Gary on your thread. I will carry out your mod :)
brake master cylinder turned up today so that got duly fitted. do you think the iva man will be happy with the arrangement around the m/c
nothing is touching. here's am overall shout of the final breakline fitted
I then made a nifty bracket for the fuel lines where they come up the bulk head
fibreglass diff panel then fitted
big box arrived today
can you guess what it is? :)
Turbocharger ???:d
it's the brake line arrangement I'm asking about btw. phone won't let me edit my post :(
Thats a bl**dy big turbo Dave :oops:
The line to the front brakes appears to be unsupported for quite a distance between where it exits the M/C to that first clip on the diagonal chassis brace?
Damn, must type faster!
don't think that would fit under the bonnet mark o_O
that's my concern mark :( it's about 200mm from the clip on the diagonal to the primary port but I guess the iva man will look at the distance if a piece of seeing was run along the pipe and then straightened out and measured?
may have to come up with a beaker of some sorts.
there is only a tiny but of flex in the pipe?
fixing a clip to the pipe under the clutch mc wouldn't add any rigidity so I think it would have to be in between somehow
bracket not beaker lol
a bit of flat bar or angle bar bolted to the bottom MC bolt with a p clip should suffice.
just need to come up with a way to make it nice and neat
oh forgot to post my last pic! rear loom has been made up. will replace the connector with some waterproof ones
At the very least spraying the interior panels black makes things easier to photograph!
That box contains a flux capacitor.
I know what the big box contains- Daves examination papers
Or maybe a Roll Cage.
