Persil Posted August 27, 2005 Posted August 27, 2005 Ok rather than replace my broken VDO Speedo im looking at fitting a Push Bike Speedo. Popped into Halfrauds and they have the Sigma ones on display but there not selling them anymore They have there own brand ones but i have no idea if they will go up to a decent speed and will got down small enough for a car wheel. The local bike shop has vdo/cateye/specialised ones but all the ones we looked at only went to 65mph or never went down small enough to use on a car . Now i have seen 3-4 people at my local meet have them fitted and a few posts on here about them so please list what model you are using (and where you got it) and any pictures of how you mounted the sensor would be nice.. Regards Persil Quote
Man On The Clapham Omnibus Posted August 27, 2005 Posted August 27, 2005 Got mine from 'alfred's and it's their £9 (ish) cheapo. Goes up to decently illegal speeds (allegedly ) and will adjust for proper wheel sizes. Quote
felters Posted August 27, 2005 Posted August 27, 2005 I had one and dumped it... bought a proper speedo. Couldn't see the numbers in a hurry. Hopeless. Quote
Man On The Clapham Omnibus Posted August 27, 2005 Posted August 27, 2005 You should have gone to Specsavers Quote
Persil Posted August 27, 2005 Author Posted August 27, 2005 Dont really need to see it in a hurry as just for a rough speed for when in areas where it matters what speed im doing. Was also planning on fitting back light led's . The other product looks lovely but at £189 i may as well buy a new vdo guage . So still looking for info on what other people use and how they have fitted them. Regards Persil Quote
Major Stare Posted August 27, 2005 Posted August 27, 2005 Look on e-Bay, there's loads ! This goes upto rdZ1QQcmdZViewItem" target="_blank">99 mph Quote
Blatman Posted August 27, 2005 Posted August 27, 2005 Loads here. Prices look OK too. If you're feeling flush then I have one of these and it's excellent with lots of toys to play with.. Quote
Man On The Clapham Omnibus Posted August 28, 2005 Posted August 28, 2005 Right! Don't buy a cordless one 'cos the distance is too great from speedo to sender. To see if you like it spend £10 at 'alfred's and get a cheap push bike one, extend the wires (twin core bell wire - easy), fix the magnet to the rear drive shaft, run the wire to the dash and fit the gauge. My magnet is cable tied to the cylindrical part of the cvj on the inboard end of the offside driveshaft and the pickup similarly cable tied to a bit of aluminium angle fixed to a near by chassis member. If you take the bootbox out it's all there to see. No pics, I'm afraid. Calibrating is easy too. There's a web site somewhere (no doubt someone will be on in a moment with the address) that tells you the rolling circumference of various tyre sizes (or "tires" as I think it is from the other side) or you can measure it yourself with a bit of chalk, a tape measure and a bit of flat tarmac. If you find the digital readout to your taste and don't mind a bit og lag in the reading it's a cheap and fairly accurate speedo. Quote
Persil Posted August 28, 2005 Author Posted August 28, 2005 Cheers Motco . The main reason i wanted to know what other people use is because alot of speedos dont go past 60mph or go down low enough in wheel size to work on a car . I dont want to really buy one and run all the cables and make brackets up only to find it does not work. I checked the cateye website last night and seems a few of there models will work...but with the bank holliday i think i will have to wait till next week to get one . Persil Quote
Blatman Posted August 28, 2005 Posted August 28, 2005 And FWIW, I had cause to recalibrate my SPA speedo this morning. I used this calculator to workout tyre circumference, and this gear calculator to work out the speed in gears based on RPM as a double check. Between them, I got my speedo to within 1MPH of actual speed across the entire rev range, although I didn't test it flat in 5th for obvious reasons... Quote
Man On The Clapham Omnibus Posted August 29, 2005 Posted August 29, 2005 I knew Blatters could be relied on despite recent minor negative comments.... Quote
steve_m Posted August 29, 2005 Posted August 29, 2005 I use a Sigma BC1200 with an extension to the wire. Quote
scooby Posted August 29, 2005 Posted August 29, 2005 I use a Sigma BC1200 with an extension to the wire. Ditto Cat Racing 7's lads use them as well . Tested mine with GPS its bang on. Loads of setting and things. Dont worry it goes WELL into Three figures i can assure you Fitting in a 7 Quote
Mole Hall Posted August 30, 2005 Posted August 30, 2005 I recently fitted BC1200 - bought on line from wiggle.co.uk Used info from site on previous reply - straight forward and easy to set up. Reading spot on!! Quote
