Cobra 427 Build
9 minutes ago, Chris King - Webmaster and Joint North East AO said:
@Gary (KugaWestie) - North Oxfordshire AO Where did you get your roller door from? Any good and how much? PM if you prefer to keep price off screen (it was £30 darling...)
https://www.rollerdor.net/shop/category/diy-roller-garage-doors/
I am happy with them for the cost.
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
So the reason I mentioned the roller door was because my wife thinks it’s a good idea as it will make getting trailer in and out much easier. She even offered to go halfers on it. Result.
So I mentioned that “one of the lads” recently fitted the type we were looking at for his Cobra build. “What’s a Cobra” she says.
So I show her a pic and now she wants me to build one!
Sadly spare cash and garage space dictate this can’t be done unless I sell the Westy.
So maybe when I retire - maybe...
1 hour ago, Chris King - Webmaster and Joint North East AO said:
Did you miss the bit about lack of cash :d
Minor detail
Anyway, back on topic...........
The new Fulcrum pins and special washers arrived today
So I have loosely fitted the lower wishbones, final torque up will be later when the car is close to kerbside weight
I am waiting for some replacement bolts to come for the front suspension, but I did have a rummage around in my imperial tray and found some nuts and bolts suitable for the front coilovers, so I hung them on loosely tonight
Front corners almost complete. I need to drop the hubs back off to fit the discs. All the bolts are loose at present, final torque up will be later
Looking good.
Must confess to slight feelings of envy that you are at the ‘bolting shiny bits on’ stage already.
1 minute ago, corsechris said:
Looking good.
I’m envious of the whole build - as is my wife :d
I got the front discs fitted this morning
This afternoon I moved to the rear of the car, and after a monumental battle I got the diff fitted complete with the wishbones. The battle involved some angle grinder work as after fitting the diff the first time I realised it was binding on a weld on the chassis, so I needed to trim this down a bit and then start again with the fitting
Pressing the needle bearings into the wishbones
A spacer tube then goes through those needle bearings, but they needed some tlc first
Before and after, cleaned up with a flap wheel
And after two hours of grunting, sweating and swearing, job done
The diff is that heavy I could not lift it, I had to wiggle it onto a jack
It’s really coming along, always looks so much better when you finish building up the suspension on an end.
