Paul Aspden (MoFast) Posted January 15, 2020 Author Posted January 15, 2020 Hi yes it does look like it was a members car as it has a WSCC sticker on the roll bar Quote
Steve (stevel) Posted January 15, 2020 Posted January 15, 2020 Yes it was my car Rear dampers were Gaz (Got to change my profile piccy) Steve Quote
Paul Aspden (MoFast) Posted January 15, 2020 Author Posted January 15, 2020 Hi @Steve (stevel) - Lancashire AO Really hope you’re back on the road in something new and shining. Thanks for the heads up on the rear damper unit. Quote
Paul Aspden (MoFast) Posted January 15, 2020 Author Posted January 15, 2020 @Steve (stevel) - Lancashire AO I have just read the story of the accident and can see that you have stepped away from Westfield ownership. Obviously got my work cut out for a few months but once this is back on the road or track you’re more than welcome to have a blast. 1 Quote
Kingster Posted January 16, 2020 Posted January 16, 2020 11 hours ago, Paul Aspden The 2nd said: @Chris King - Webmaster and Joint North East AO Would you be willing to sell the right hand drive shaft? Mine are different I’m afraid. Older push in shafts, Quote
Kingster Posted January 16, 2020 Posted January 16, 2020 Crickey - as you say you’ve got your work cut out with this one! Quote
Paul Aspden (MoFast) Posted January 16, 2020 Author Posted January 16, 2020 Yeah but as always it's the journey not the destination. Thanks for the heads up on the shafts. About to hit Lobro's dataset now to see if i can source. That said if the shaft is still straight i might just rebuild the CV joints Quote
Kingster Posted January 16, 2020 Posted January 16, 2020 CPS Drivelink up near here in Gateshead will make you a new driveshaft. I’m going to need some myself as although I have 2 sets, one is too long and the other too short! (Don’t ask...) Quote
Paul Aspden (MoFast) Posted January 16, 2020 Author Posted January 16, 2020 3 hours ago, Chris King - Webmaster and Joint North East AO said: CPS Drivelink up near here in Gateshead will make you a new driveshaft. I’m going to need some myself as although I have 2 sets, one is too long and the other too short! (Don’t ask...) I am assuming that the drive shafts are equal length so will measure up the good one one once off the car. Thanks for the heads up on CPS. Quote
Paul Aspden (MoFast) Posted January 16, 2020 Author Posted January 16, 2020 Does anyone know what the wheel PCD and offset will be on this car so i can sort wheels in advance? Quote
Dave Eastwood (Gadgetman) Posted January 16, 2020 Posted January 16, 2020 41 minutes ago, Paul Aspden The 2nd said: I am assuming that the drive shafts are equal length so will measure up the good one one once off the car. Thanks for the heads up on CPS. If it's a Sierra diff in an SEi, they're different lengths, I'm afraid. How funny, just Googled for an image, and got one of my own! Quote
Kingster Posted January 16, 2020 Posted January 16, 2020 1 hour ago, Paul Aspden The 2nd said: Does anyone know what the wheel PCD and offset will be on this car so i can sort wheels in advance? pcd is std Ford 108 Offset can vary - but for your age of car I’d say it’s very likely to be et23 for a 7” rim Quote
Paul Aspden (MoFast) Posted January 16, 2020 Author Posted January 16, 2020 Can anyone help identify if the front is wide track? Quote
