Parts for Scott's Stoneleigh conversion to fuel injection
Here is the thread for anyone that missed it - we're doing OK towards preparing for Stoneleigh, but need help with some specific parts please that must be gathering dust somewhere:
I have a Ford coilpack and leads off a Zetec. Any good?
Yes please to the coilpack, Chris. 1st or 2nd gen? Can you send a photo please so we can get Ka plug leads to suit?
Will post a pic. Think I have 2 spare ones.
brilliant, thanks Chris - that'll be perfect for Scott. Please can you also just measure the diameter of a coil posts with a lead pulled off? Something rough like 15 or 18mm I think - then we can get Ford Ka leads to suit.
Yes will do. Just got in from the man cave and missed this so will do it next time.
Approx 15mm wide
I bought a duratec crank sensor direct from local Ford garage and the alignment tool comes as a kit. Cost £30 and came day after purchasing.
I have a cvh crank pulley with the rest of an engine attached to it :t-up: will pull off next time I'm at the garage.
sorry mike i keep forgetting to measure that trigger wheel. ill definetly do it tonight
Hi Mike
I have an ECU air temp sensor off my Duratec if it's any good to you.
Yes, please Nic! If @Scott Young - WSCC Chairman could send you some postage, please could you send to Luke @Plays-Kool for loom matching? Can you shove a photo on here  too, please?
Yes please!! Assuming it is the same as this, if @Scott Young - WSCC Chairman sends postage, could you send to @bunje? Then, Ben can attach a trigger wheel (either his own, or a new one we'll get) and send on to Scott, who can make a cardboard sensor template to send back to Ben, to turn into steel, to... You get the idea :) We can return Scott's old pulley to you in exchange...
Photo as requested. Is this any good?
