Dear Diary: My journey from Xflow to Zetec... Now definitely done!
I used rmp1305 and the associated heavy duty plate and release rmp1772 and rmp1706
From dunnel
None of this p******** about which a one off this or that.
Used with ecb113 from Burton
Hi Q
The clutch is off a Mondeo Mk1 1800 16v - early ones have the correct 23 splines you need and correct dia for the flywheel which will be off a 1.8 focus (lighter than 2.0) both will be 220mm dia.
You need a spigot bearing - but that will probably still be in the crank on the new engine if it came out of another Westy.
The clutch release bearing is a QH CCT133
If you want to spend more money, look at getting a lighter flywheel - mine's a billet steel one from Ginetta that weights about 3.5kg and the car spins up a treat!
Cheers Chris, it's good to know what I should look for when trying to find what works or not. I can only find non OEM clutch kits, so may have to visit a Ford dealer and see if they can still provide a price/supply. With regards to the Focus, do you know what Mk it should be? Mk1 as well?
Not sure if the spigot bearing is included (had to google what it is ;)) but if it is on the crank on the engine, then I would imagine it is included.
From dunnel
Short and to the point, eh? ;)
I make that this, this, this and this then?
You could also try Retro Ford. They supplied everything I needed clutch/flywheel/bearings for my recent Zetec/type 9 instalation.
I'll try and dig out details of the ones I got prior to using the light flywheel as long as Dom promises not to tell me off ;)
I don't suppose you still have your 'shopping' list from them?
Ive had a quick look in my emails but dont seem to have an order invoice. The flywheel was: http://www.retro-ford.co.uk/shop/node/174
As for the other parts required they will be able to tell you, as they did for me.
Oof, that is nice... at a price... Maybe next year ;)
That's like the one I have, but mine suits the 220mm Mondeo clutch - I believe the Pinto clutch needs the mounting holes drilling out (or something??)
I have a new clutch and flywheel that came off my crate Zetec - but pretty sure it's wrong splines and positive its stupidly heavy!
Checked the 'bay for the kit I bought originally, but listings are too old - so all I can offer is the following info:
http://www.ebay.co.uk/itm/Clutch-for-FORD-Mondeo-Mk1-93-96-1-8-16v-2-piece-kit-1796cc-8-94-7-96-2-Pie-/361708212769?hash=item54377d5221:g:dmEAAOSwgmJXxyJG this will fit - 220mm with 23 splines
Can't find a flywheel but is a Ford zetec off an early mondeo/escort/fiesta 1.8 - but not a zetec turbo - 220mm and with trigger holes on the back.
I've found these guys good for tuning parts (VX and Ford) - near Bedford so can save on postage.....
http://www.turbosport.net/acatalog/Zetec_engine_parts.html
I sort of agree with the idea of getting all the parts from one source - I nearly did that with QED but in the end I probably saved over £500 by shopping around (for identical parts - just often cheaper elsewhere). Apart from the cost saving it also helps you to understand how everything works and fits together (though keep a list of things in a spreadsheet for later !!)
Can't guarantee that Chris .. blame the physicists at the mo ;) your right about the mounting holes tho.
Quinten they look right to me. But best ask dunnel before you order as they are generally great at advice.
I think they even sent a new set of bolts for the flywheel
  • 3 weeks later...
Step 1: collect engine... Done!
What do you plan to do with the rest of the car ??
:rolleyes:
Especially for you Colin, here's one half of the V8 in that car ;)
Hi Quinten,
I might be interested in some of your crossflow bits, when you start the conversion.
Gary
