Eclectic electrics
I reckon they are, cheers! Site bookmarked for tomorrow to compare against the real thing (I'll be the 1st to admit that my photos are crap ;):yes:
Now for your next challenge ;)
Trying to find out which wire is what on my ignition barrel. I've got the Allegro column (19mm/48 spline), so I presume an Allegro ignition barrel? First position (from off) unlocks the steering lock, second position 'activates' the car and third (returns to second position) starts the engine.
The dash wiring looks okish from here but those blue and red aluminium crimps have to go.  the 'House' connectors, as you say, are on my headlight connectors, don't know what they called either.
Off the top of my head ... Brown is "live" power (always on), White/Red is to starter motor solenoid, White goes to Fuse box to supply power to "vital" things (fuel pump, ignition etc) whilst Green goes to the other fuse box for lights etc (I think - I did check this out on mine a while back but I can't find the piece of paper I wrote it down on !!), So lights will work at any time but fuel pump / ignition only when ignition switch is on and obviously starter only when turned to "start"
Cheers again. Hopefully armed with the above I should be able to confirm that.
So the plugs are indeed the ones from Autosparks, and I'm going to need 3x 5-way and 1x 7-way. Now I am just wondering which blade terminals I should be going for
or
My plan is to put most of the 'gear' behind relays, so I think I'll only going to need 1mm2 thin-wall (16.5A) for the switches and instrument lighting.
The bottom type. With a decent crimper, and that doesn't necessarily mean a massively expensive one, "F" crimps like the bottom type will give good solid reliable crimps, time after time.
Cheers Dave! As I'm completely starting from fresh, it's good to hear the voice of experience. Had already bookmarked a crimp tool previously recommended (http://www.ebay.co.uk/itm/181460919306) on the forums (can't remember which thread it was though) which is hopefully a decent enough one.
  • 3 weeks later...
Ok, I've been a dumb *rs and not paid much attention to the inidcator/hazard light situation and now it is all in bits, it's a bit of a mystery how the Westfield Self-Cancelling Indicator module, the hazard switch and the flasher relay(s) operate together...
The self-cancelling module has 3 cables coming out of it
1) a pair of red and black, which are live (but is it permanent or ignition switched live?) and ground. This is the easy bit ;)
2) a trio of wires; green/red + green/white, which are going into the indicator switch; and a red/black wire which is the common on the indicator switch. This I could still make out...
3) a trio of wires; green/red + green/white, which are connected to the tell tale light (both to a different leg, so I assume current flows either from green/red to the green/white, or the other way around?) and then a mysterious green/brown wire which according to my label connects to the hazard switch... but why? Does anyone have a clue?
I suppose if anyone has the installation instructions for the self-cancelling module handy, then that may help already...
Just had another thought, could the green/brown wire be (through the hazard switch) from the flasher relay? That would sort of make sense to me...
id sort of agree.
brown is direct to battery, red white is starter white is to the fuses and the green is a switched or permanent live (things like the fan that may be controlled by a swtch but needed when ign is off) you could check the connections using a meter. see what continuity there is between stages of the key turn.
if nothing between the brown and green then its a switched live, if there is then its a permanent live. quineten your assumption may be along the right line, the hazrd switch needs a permanent live connection so the flashers work when the ign is off. on my car dark green is permanent live
cant remember the green brown, i think its to the flasher relay id need to check on a diagram. the green red and green white are for the LHS and RHS of the car.
Yeah, I figured the ignition barrel wiring out already.  I'm now only after the wiring instructions for the self-cancelling module from Westfield to confirm what I think it does...
i found the indicators to be the most complicated bit of the wiring. although it became the most simple bit for me when i used a self cancelling motorbike type box as all of the hazard switch/relay etc was removed and replaced by 7 wires. 2x live 1 earth and 2 outputs and 2 inputs. :) i have also built a little loom that the original system can be used to implement the original system tho.
Don't find the indicators really that difficult, just the little black box without instructions...  May have to resort to a bench test instead...
No-one got the instructions? :(
  • 1 month later...
Hazards%2BIndicators.png?dl=0
I reckon the above should take care of the hazards and the indicators. Any comments?
