Maintaining a Westfield
Most odd. May be worth trying to ascertain a manufacturer ID and checking on the service life. Or perhaps a call to one of the prop specialists like Bailey Morris for some advice...
  • Replies 43
  • Blatman
    11
  • stephenh
    8
  • Martin Keene
    7
  • adamnreeves
    6
A quick google finds this:
Bailey Morris Technical
Seems like there are sealed for life props. I guess mine isn't a Westfield item then, must be Bailey or Reco or A.N. Other
One thing less to worry about :t-up:
Indeed. Thinking about it some more SWMBO has an S2000 which doesn't need the prop greasing according to the service schedule. And I can't believe all these BMW's, Merc's, Lexi, etc need it doing in this day and age either.
It's a fair point. I've just never seen a Westfield supplied prop without grease nipples. You learn something new every day...
  • 2 weeks later...
Ok guys, mainly because I am bored waiting for the DLVA I am going to design a service booklet. Watch this space!
What do you reckon to this for a format? here
Its in B5 size.
So something like:
Service 1 - Every 12months or 10,000 miles
• Change engine oil and filter
• Replace or re-oil air filter
• Check and top-up brake/clutch fluid
• Check coolant level
Service 2 - Every 24months or 20,000 miles
• Change brake/clutch fluid and bleed brakes
• Replace spark plugs
• Inspect CVJ boots
• Inspect all suspension bolts
• Grease prop-shaft UJs
Service 3 - Every 36months or 30,000 miles
• Replace coolant
• Check transmission oil and top-up
• Check differential oil and top-up
• Check condition of fuel and brake lines
• Check suspension alignment
Service 4 - Every 48months or 40,000 miles
• Replace fuel filters
Service 5 - Every 60months or 60,000 miles
• Replace transmission oil
• Replace differential oil
• Replace Cam-belt where fitted
Format looks good mate.
I'd base the mileages on average annual mileage, so maybe a quick poll to gauge average mileage.
I wasn't sure what to do with mileages, maybe base on 5,000 pa. but I figured that in most cases the time will come round first.
Latest version of the service booklet here
Thanks Adam,
I'll be printing this out and using it  :D
Another link in the FAQ section...?
Dom
Excellent job Adam  ;)
Just 1 print error on page 20  :blush:
2x rear ride height :p
:t-up:  :t-up:
:t-up:  :t-up:
One should have been damper rate. corrected and re-published. Download again. You may have to type ctrl-f5 in your browser if you viewing directly.
