Cleggy's Spyder Rebuild 17 07 09
jago got stuck in the other night then mate did he sleep in the garage.
i got a bit wet on the way home :D
speak later
tony
Yeah We got on and very quickly dismantled the whole front end - no siezed ball joints which was a blessing - just a little persuasion with a ball joint tool
There was no chance of nodding off - today I have picked up some Gunk/wire brushes and masking tape - so next job is to finish off labelling up the wiring on the engine and starting to clean up the components before removal of the engine
Dave has very kindly leant me his engine stand - good on yer Dave  :t-up: so it looks like Jago is hopefully over again Wednesday night - if you are at a loose end m8 and fancy a ride out pop over (I know you are like me, any excuse to take the Westy out  :D )
Hopefully my new shiney bits will have arrived by then so we can have a rummage through some boxes to look at the bling  :D
If any of you local boys wanna pop over to lend a hand or just yer brain just let us know - all are welcome  :t-up:
Sam - come and get yer heat exchangers m8
To make the thing a bit more pleasant to work on ready for the engine out job I have just spent the last hour or two with my old m8 Gunk and his best friend Mr Pressurewasher
it's gone from this
to this - nicely cleaned ready for engine out and chassis away to be shot blasted
the adjusters for the front beam should be here this week so front axle is cleaned up a little ready for them to be fitted
You're putting alot of hard graft in there mate, keep it up.
Dave
Hey Dave - will be good when all the parts are cleaned up and shot blasted - wil make things much more enjoyable  :t-up:
Christ I thought a Westie was hard but this lloks like a proper job. Keep it up Cleggy and keep the posting going. Looks like the Cambs boys are providing the education this summer with Chaz having made the effort as well.
Thanks - I dont have Chaz's extpertise but hopefully I can make up for that with a bit of effort
Was watching that! just out of interest  :laugh: it looks a bit rough but went for £4,678.00  :bangshead:
they have their handsful like me now - got the engine out last night Dave  :t-up:
hope to see it saturday cleggy.
up to my neck at the mo so couldnt get up to your place.
cheers
tony
See you Saturday Tony --- can you get over tomorrow night -- I still have not tested this route yet -- you fancy it or are you gonna be away?
anyone else fancy a ride out Fri night to test the route for Saturday Maxey run out ?
will call if its possible.
Well back to the build - or should I say dismantling - had another good session with me old m8 Jago and managed to lift the engine out - it was quite manageable with two
The engine is now out and resting on the floor - the bracket is attached to the casing ready for lifting onto the stand (need some m8's for that bit)  :D Unfortunately I did not have any bolts long enough so you can guess where I visited today
This one shows the gearbox and axle/drum fully un-bolted ready for some m8's to come give me a lift -- come on it's a team effort  :D
This pictures shows the only nut/bolt that has proved to be a total b***h to get un-done - would of helped if I had of had a suitable sized socket - but hey I dragged out an old family heirloom - a rather rusty but large adjustable spanner - so with the help of a jack under the drum and a sledgehammer I gently teased the nut loose  :D
Here are the axle adjusters - need to ring a new contact with the knowledge to fit them next week - you will also notive some bling items - nothing too tacky just a bit of alloy here n there with some nice yellow ignition leads
More bling - probably getting ahead of myself here - but boy does it make me feel better  :p
This picture just makes me feel a bit better about life in general
and this one just cause I felt like it  - wont be long before your back in the garage - she's been left at work and is feeling a bit neglected at the moment  :laugh:
the boys were saying to each other at the time of the picture
what the hell has he bought here!!!!!!!!!!!!!!!!!!!!!!! :devil:  he should have bought buttons veyron :D
Couldn't afford Buttons button off his shirt  :D
More progress - managed to man handle the gearbox/drive shaft/drum assembly off myself this morning
and with Tony and Daves (Dave from Leicester) help we managed to get the engine onto the stand (thanks Dave from Peterborough) way too many Dave's involved in this  :D
time for a shuffle around in the garage to make room and make things a bit easier to work on - chassis temporarily lifted up out of the way whilst engine and gearbox get moved to the back of the garage
