Cleggy's Spyder Rebuild 17 07 09
any night at present is good just let me know.
see you guys tonight  :t-up:
Hopefully wont be to late, got a little job to do first  :t-up:
Thanks Dave and Tony for your help tonight - could not have done it without you  :t-up: was good to get heads together
good progress made tonight - Tony and I managed to get the rear axle bolted up ready for when Dave arrived
then it was a matter of lifting the front bodywork section into place, we soon however realised that there was a small section of the jig that needed to be lopped off with the angle grinder and also that the fron t suspension was let too low after having the adjusters fitted
10 minutes later with an angle grinder and a jack for th adjusters the body was being trial fitted
good news - the new floorpan edges are spot on and the body now sits much more level than previous -
bad news - the body is still sitting high on one side at the front, so looks like I have some adjustment of the tub to do at some point
flintstones, meet the flintstones !!!
another update tomorrow - thanks again chaps
pheonix rides again  :)
phoenix will get taken to bits again  :laugh:  but it was nice to see the body sat back on if it was only temporarily  :love:
your new avatar is orrible!!!!!!!!!!! :laugh:
Oh Really  :p
stop  :arse:  about with you avatar and bring back spiderman i miss him  :p  :D
oh really  :p  :cool:
silly sod!!!!!!!!!!! :laugh:
after a session messing about with seat heights midweek I have decided to lower the seat height which means some extra fabrication on the pans - I rather amusingly at the time spent 15 minutes sitting on a stack of floor tiles trying to determine where my head would sit when plonked in the seat - glad it was just me and Jago in the workshop and that no photographic evidence exists  :blush:  :laugh:
after thinking about it for a few nights I decided to weld on some cross pieces of 25 x 25 mm (not done yet) and then to make up some lowering framework for the seat
first job to decide on the angle and cut four identical pieces to size - off to my best friend (apart from Mr Angle Grinder) Mr Chop Saw - cannot believe what short work this machine makes of cutting up metal
then using a good flat tile on me trestle stands make up the first piece using that as a sample to ensure all the other angles remain the same
then to the other end
all four pieces spot on
showing how the seats will sit onto the framework when welded up onto the chassis - this things gonna weigh a ton  :laugh: gonna need more than 50 bhp  :suspect:
Use your Westy engine  ;)  ;)  :p  :p  :laugh:  :laugh:
:laugh:  maybe not
tonights job see the front lowered floor pan support going in - my main concern was again matching up both sides so that you could look across from the side of the car and see that a perfect straight line through
as I was using one piece for each side I decided to clamp on one long piece underneath - to this I simply tacked on a small bit of box section either end so that it went below the centre tunnel - I then measure from the the rear hat 730mm forwards on both sides
cut the bits to size and tack in place
welded along top
and finally the money shot - do they line up?
yup thank the lordy  :laugh:
