Bob Green Posted July 12, 2008 Share Posted July 12, 2008 Jesus Christ!!! That is a proper turbocharger. What ECU will it use and what is the anticipated power output? Quote Link to comment Share on other sites More sharing options...
Paul Ash Posted July 12, 2008 Share Posted July 12, 2008 It needs a Turbo that big, as its just doubled the weight of the engine Quote Link to comment Share on other sites More sharing options...
Blatman Posted July 12, 2008 Share Posted July 12, 2008 Alternator mount doesn't look particularly svelte either, and it's still too close to the manifold. I reckon it'll need a heat shield similar to what they use on the space shuttle Looks like the engine has been treated to some steel bore liners too. Quote Link to comment Share on other sites More sharing options...
FW500 Posted July 12, 2008 Share Posted July 12, 2008 It'll be running an Autronic SM4 ECU as the engine builder is the same guy who maps mine - Mark Shead at MADevelopments and I know he only deals with Autronic. Mark drove this car (Sierra Cosworth) on 5th Gear at 206Mph. That was with the old turbo - with around 800Bhp. This turbo is much bigger and the engine is expected to be delivering somewhere around the 1000Bhp mark. Rod Tarry (The car's owner) is a complete lunatic... and a pensioner too! Quote Link to comment Share on other sites More sharing options...
Bob Green Posted July 13, 2008 Share Posted July 13, 2008 Alternator mount doesn't look particularly svelte either, and it's still too close to the manifold. I reckon it'll need a heat shield similar to what they use on the space shuttle I totally agree. You will end up with the Alternator dripping on the ground! On my factory built car, the Alternator is mounted on the left of the engine using a fabricated bracket bolted to the three pre-tapped drillings in the block. Quote Link to comment Share on other sites More sharing options...
