perksy Posted July 9, 2008 Share Posted July 9, 2008 PerksyCan you explain why you have the breather from the rocker cover to the block, blanked off? Benefit etc Dry Sumped Mate SBD do a kit for Blanking off the Cam cover etc if req'd Quote Link to comment Share on other sites More sharing options...
originalgeezer Posted July 9, 2008 Author Share Posted July 9, 2008 Cheers Guessed it maybe but wanted to make sure before assumed I have the rocker cover breather on the other side vented at present - needs a catch tank arrangement to do it properly and the smaller one blocked. Quote Link to comment Share on other sites More sharing options...
stu999 Posted July 9, 2008 Share Posted July 9, 2008 Cheers Guessed it maybe but wanted to make sure before assumed I have the rocker cover breather on the other side vented at present - needs a catch tank arrangement to do it properly and the smaller one blocked. Might be worth checking to ensure that the rocker cover breather mod has been done too - if you don't already know that is... You will have to take the cover off to see though Quote Link to comment Share on other sites More sharing options...
perksy Posted July 9, 2008 Share Posted July 9, 2008 As Stu says well worth checking to see if this has been done Link to Mod' is HERE Quote Link to comment Share on other sites More sharing options...
originalgeezer Posted July 9, 2008 Author Share Posted July 9, 2008 yeah have looked into the mod and have plans to take it off to confirm before, though it should be as the engine was a pro build - but i am still going to check also, need to look closer at things like the alternator that has been relocated to the exhaust side of the engine, but not sure without looking more if that was to accomodate the oil filter take off pipes as it has remote oil filter. engine and car wise it looks all there, just as with these things they havent all been done that well, or tidy to be more accurate. Quote Link to comment Share on other sites More sharing options...
westy turbo Posted July 10, 2008 Share Posted July 10, 2008 The cam cover mod has to be done even if you are using the dry kit? Quote Link to comment Share on other sites More sharing options...
Bob Green Posted July 10, 2008 Share Posted July 10, 2008 Sorry, I haven’t got an XE engine but if you want to see a proper engine, look no further. Quote Link to comment Share on other sites More sharing options...
Blatman Posted July 10, 2008 Share Posted July 10, 2008 Nice engine but some b*** has strapped a hairdryer to the side of it Quote Link to comment Share on other sites More sharing options...
Bob Green Posted July 10, 2008 Share Posted July 10, 2008 Got to keep my grey hair in place! Quote Link to comment Share on other sites More sharing options...
stu999 Posted July 10, 2008 Share Posted July 10, 2008 The cam cover mod has to be done even if you are using the dry kit? No need if dry sumping - if the dry sump kit you use will allow all of the engine breathers to be blanked off (like Perksy's). However, if turbocharging you may find it better to run with a breather system too (as you may probably get more 'blow-by') - in which case the mod will be a good idea Quote Link to comment Share on other sites More sharing options...
westy turbo Posted July 11, 2008 Share Posted July 11, 2008 Yeah,going on the turbo route....i quess ill cut that,underneeth the cam cover,so it stops smoking...its but for it... Quote Link to comment Share on other sites More sharing options...
mr-rad Posted July 11, 2008 Share Posted July 11, 2008 As mentioned above, got the reducer from Silicone hoses. The metal bit below it is a standard pipe for the XE, bolts directly to the block ...... don't you have one MR Rad? Tiggs No just a dodgy rubber pipe between block and rocker cover. I'll be at a scrappies this weekend to see if I can find a proper one. It looks so much tidyer than mine. Quote Link to comment Share on other sites More sharing options...
FW500 Posted July 11, 2008 Share Posted July 11, 2008 Sorry, I haven’t got an XE engine but if you want to see a proper engine, look no further. Pah - that's just kid's stuff - this is a proper cossie engine (Rod Tarry's): Quote Link to comment Share on other sites More sharing options...
Matt Seabrook Posted July 11, 2008 Share Posted July 11, 2008 bl****ell! That turbos a bit big Quote Link to comment Share on other sites More sharing options...
Paul Ash Posted July 12, 2008 Share Posted July 12, 2008 QUOTE Paul Do you have any pictures of battery location and header tank as these are two things i am looking to re locate as they are both on the scuttle at present. Pictures with the Nose off? Heres some pics:- Earlier version of install, prior to dry sumping. HTH QUOTE bl****ell! That turbos a bit big That is a big Turbo Quote Link to comment Share on other sites More sharing options...
