Scottish Bloke Posted October 3, 2007 Posted October 3, 2007 I'm now in a position to produce some more Half Doors. Initially I'm looking for numbers, format will be to PM me with your note of intrest, once numbers are confirmed I'll be looking for a £70.00 deposit. Total cost will be £140.00 inc P&P. Doors are designed around a wide body car, but I'll make some narrow ones if there's enough interest, say six sets. The Doors are moulded and contoured to be a perfect fit then trimmed on the outside with soft top grade vinyl and inners are trimmed with black felt used for soft top headliners. There's a few sets in circulation, you might have seen them around. I've had a few enquiries about these so roll up roll up Regards Rich Pls. PM for pics, can't post at moment for some reason
Asterix Posted October 3, 2007 Posted October 3, 2007 bad url rich...and can you wait until the end of the month, need to check fitment on the new car
perksy Posted October 3, 2007 Posted October 3, 2007 Pls. PM for pics, can't post at moment for some reason Rich Send to: mark.perksy@btinternet.com and i'll post 'em up for you if you'd like
Asterix Posted October 3, 2007 Posted October 3, 2007 enough of the bonnet aerofoils, where's the halfdoors?
Crazy Eddie Posted October 3, 2007 Posted October 3, 2007 enough of the bonnet aerofoils, where's the halfdoors? Actually I'm interested in these, are there any pics about with them fitted on the car please? (And how do they mount?) Cheers Eddie
Evo,s 7SE Posted October 3, 2007 Posted October 3, 2007 i would be interested in a set for a narrow (prelit)would just need measurements to check they would fit .also how do you normally fit them press studs?
Mark Stanton Posted October 4, 2007 Posted October 4, 2007 Fitted mine as have a few others in the SS with press-studs about 9 or 10 around perimeter into bodywork and they're just fine - someone with a bit more skill time and patience would probably be able to make a hinge etc etc etc
Cam Posted October 4, 2007 Posted October 4, 2007 Rich............ Forgot to ask. Do you know if these will fit a wide body with a full cage?
Scottish Bloke Posted October 4, 2007 Author Posted October 4, 2007 Rich............ Forgot to ask. Do you know if these will fit a wide body with a full cage? The honest answer is I don't know but I'll try and find out, don't see why not but may need a bit of fettling. Rich
