volvorsport Posted May 28, 2007 Share Posted May 28, 2007 just been reading - the 2 litre BTCC engines used a 73.9mm crank , so something special in there . they did however use an 83mm block so at least youve started with the right one !!! Quote Link to comment Share on other sites More sharing options...
RS WST Posted June 4, 2007 Author Share Posted June 4, 2007 Manifold on its way Quote Link to comment Share on other sites More sharing options...
RS WST Posted May 10, 2010 Author Share Posted May 10, 2010 After over a year of waiting I finally got my head and cams back from QEP / Cat Cams Just need to get some pistons made and I can start bolting the engine together. Need to redress the inlet valve seat area and skim the head also Quote Link to comment Share on other sites More sharing options...
FW500 Posted May 10, 2010 Share Posted May 10, 2010 Impressive as usual Austen. What's going on with the injectors - looks great but can't work out how it all works. Quote Link to comment Share on other sites More sharing options...
RS WST Posted May 10, 2010 Author Share Posted May 10, 2010 I'm running 2 banks of injectors, one close to the head and another set firing down the trumpets Outer set will come on further up the RPM range Quote Link to comment Share on other sites More sharing options...
FW500 Posted May 10, 2010 Share Posted May 10, 2010 I see - ah just realised this isn't turbo'd anymore is it? I was wondering how it would all sit inside a plenum but then noticed the length of the trumpets. Quote Link to comment Share on other sites More sharing options...
RS WST Posted May 10, 2010 Author Share Posted May 10, 2010 Decided to run nasp in the end More controlable than a point and squirt turbo IMO Quote Link to comment Share on other sites More sharing options...
Paul Aspden Posted May 11, 2010 Share Posted May 11, 2010 So I gess the head is off to JWT at Stanwoods for a skim? and order the pistons whilst your their? Nasp is defo the way to go, you've sampled turbo power and you nkow what its like in 500kg car, so why repeat yourself? keep up the good work mate. Quote Link to comment Share on other sites More sharing options...
Buzz Billsberry Posted May 11, 2010 Share Posted May 11, 2010 Austen you need to get a girlfriend with big breasts... engines are ruining your life!! Buzz Quote Link to comment Share on other sites More sharing options...
RS WST Posted May 11, 2010 Author Share Posted May 11, 2010 Thanks Buzz I'll take your advice on board Engines are probably the cheaper of the two however from my experience Going to see Jonny next week to get the head skimmed and spec pistons Turbo power was good but not as responsive out the bends and has way too much torque for such a little car so we shall see how nasp performs If it's not fast enough a sniff of NOS should sort that out Quote Link to comment Share on other sites More sharing options...
Buzz Billsberry Posted May 11, 2010 Share Posted May 11, 2010 Whens the official launch??? Are you bring it to Le-Mans?? Buzz Quote Link to comment Share on other sites More sharing options...
RS WST Posted May 11, 2010 Author Share Posted May 11, 2010 I doubt it will be ready this year the wait on pistons is 8 weeks from order alone Quote Link to comment Share on other sites More sharing options...
RS WST Posted May 11, 2010 Author Share Posted May 11, 2010 I hope it sounds like this Quote Link to comment Share on other sites More sharing options...
RS WST Posted June 4, 2010 Author Share Posted June 4, 2010 2.0l crank Quote Link to comment Share on other sites More sharing options...
Bananaman Posted June 4, 2010 Share Posted June 4, 2010 Very shiney, when are the pistons coming? See you in Le Mans............... Quote Link to comment Share on other sites More sharing options...
