RS WST Posted November 27, 2006 Author Share Posted November 27, 2006 Does anyone have any info on these engines, (bore, stroke, rod length etc?) and what aftermarket tuning bits are avaialable for them? Quote Link to comment Share on other sites More sharing options...
scott beeland Posted November 27, 2006 Share Posted November 27, 2006 Jesus Austen...You're getting as indecisive as Stu Pickles over this ST engine Quote Link to comment Share on other sites More sharing options...
RS WST Posted November 27, 2006 Author Share Posted November 27, 2006 Still doing the ST170 engine Just planning ahead for the next project Quote Link to comment Share on other sites More sharing options...
Nick A Posted November 27, 2006 Share Posted November 27, 2006 RS WST PM sent Quote Link to comment Share on other sites More sharing options...
samcooke Posted November 27, 2006 Share Posted November 27, 2006 http://turbobricks.com/ Quote Link to comment Share on other sites More sharing options...
volvorsport Posted November 27, 2006 Share Posted November 27, 2006 youll find me on there also !! Quote Link to comment Share on other sites More sharing options...
RS WST Posted April 21, 2007 Author Share Posted April 21, 2007 There are a couple of 2.5 Volvo 5 cylinder alloy engines in the local breakers for £90 each Can anyone give me details of if this is a good base engine to use? Is the bell housing on these the same pattern as a VW? Quote Link to comment Share on other sites More sharing options...
volvorsport Posted April 21, 2007 Share Posted April 21, 2007 nope and nope you could use them for setting up , the bore is too large , start with a 2.3 . Quote Link to comment Share on other sites More sharing options...
Flan Posted April 24, 2007 Share Posted April 24, 2007 You mentioned the 328 e30 box can that be bolted straight to the T5 lump or will you need an adaptor plate. also someone said you could also run a M90 5-speed out of a late model 960 im still curious. Quote Link to comment Share on other sites More sharing options...
slippy Posted April 24, 2007 Share Posted April 24, 2007 This the one Quote Link to comment Share on other sites More sharing options...
Flan Posted April 24, 2007 Share Posted April 24, 2007 No thats only a 4pot i think, Quote Link to comment Share on other sites More sharing options...
volvorsport Posted April 24, 2007 Share Posted April 24, 2007 getrag adapters are available for £130 from here www.klracing.se find a straight six manual from a 960 and youre set with an M90 . most guys fit a getrag for serious abuse . especially if you want it to fit in your tunnel . that manta engine , is based on the redblock from the 2/7/9 series , where they basically buy a marine crank/forged rods/pistons for about £1600 , stick a 16v head on it , double valve springs , enough hardware to support 2 bar of boost - 500bhp . ive built one for a customer . yes it is a heavy engine , the whiteblock is lighter - but not that much in 5 cyl guise and if youre serious about it , youll definitely need good tyres . Quote Link to comment Share on other sites More sharing options...
LordB Posted April 24, 2007 Share Posted April 24, 2007 Still doing the ST170 engine Just planning ahead for the next project Austin, I might have to take out my Cosworth then!! INTERESTED?? Obviously NOT before Le Mans! Rich Quote Link to comment Share on other sites More sharing options...
RS WST Posted April 24, 2007 Author Share Posted April 24, 2007 Still doing the ST170 engine Just planning ahead for the next project Austin, I might have to take out my Cosworth then!! INTERESTED?? Obviously NOT before Le Mans! Rich I'm game if you are? I'm also looking at using a 5 cylinder Audi lump as my mates engine made 640bhp at the wheels the other week. Quote Link to comment Share on other sites More sharing options...
nikpro Posted April 25, 2007 Share Posted April 25, 2007 Austin, before I got into Westfields I used to be involved in tuning Volvo T5's (I know a strange choice!) The engine is a good engine and can easily produce 300 bhp but after that you hit all sorts of problems. The weak link is the con rods that tend to bend - they really don't like high boost/lowish revs situations. There are very limited aftermarket suppliers for the engine and I would suggest there are far better alternatives for a Turbo Westfield. The tuning website I ran was T5uk.com (Think this now links to a porn site! - so don't try it if you are offended) Most Volvo tuning revolves around an ECU re-map to increase the boost pressure. Quote Link to comment Share on other sites More sharing options...
