Blatman Posted January 9, 2006 Share Posted January 9, 2006 Wire wool is not an appropriate silencer packing material... Quote Link to comment Share on other sites More sharing options...
slippy Posted January 9, 2006 Share Posted January 9, 2006 An alternative would be I'm talking just to pass noise test here Quote Link to comment Share on other sites More sharing options...
Blatman Posted January 9, 2006 Share Posted January 9, 2006 Proper silencer wadding, available from all good Motorsport and many after market exhaust suppliers... Quote Link to comment Share on other sites More sharing options...
slippy Posted January 9, 2006 Share Posted January 9, 2006 How many £££££££ are we talking and do people generally take it out after scruit ? Quote Link to comment Share on other sites More sharing options...
Blatman Posted January 9, 2006 Share Posted January 9, 2006 Take it out? No, you leave it in. Most tracks check drive by noise too. Silencer wadding is what is currently in yours, and every other repackable silencer out there. It gets burned away slowly over time so it needs replacing periodically. You don't fit it/remove it as necessary... About 30 quid for a silencer full. Check Merlin, Rally Design, Demon Tweeks etc. All will be revealed... Quote Link to comment Share on other sites More sharing options...
Blatman Posted January 9, 2006 Share Posted January 9, 2006 Merlin Motorsport... Quote Link to comment Share on other sites More sharing options...
slippy Posted January 9, 2006 Share Posted January 9, 2006 I was measured at Donnington at 103db is that loud ? I know most circuits noise resrtictions differ but most I have sen have been around 105db Quote Link to comment Share on other sites More sharing options...
Blatman Posted January 9, 2006 Share Posted January 9, 2006 Is 103db loud? It is if the limit is 100db... The dbA scale of noise measurement is a logarithmic scale, so 102dbA is (roughly) twice as loud as 100dbA. Quote Link to comment Share on other sites More sharing options...
Barry Ashcroft Posted January 9, 2006 Share Posted January 9, 2006 I was measured at Donnington at 103db is that loud ? It would fail SVA I certainly did at 109db Quote Link to comment Share on other sites More sharing options...
slippy Posted January 9, 2006 Share Posted January 9, 2006 My first real event bar Donnington is Harewood and the limti is 103db according to the application form so I am boredline Quote Link to comment Share on other sites More sharing options...
Blatman Posted January 9, 2006 Share Posted January 9, 2006 So repack yer silencer, assuming you have a repackable one... If not, then there is no simple answer unless you spend £££'s... Quote Link to comment Share on other sites More sharing options...
slippy Posted January 9, 2006 Share Posted January 9, 2006 So if I'm over the noise I'm fooked ? Quote Link to comment Share on other sites More sharing options...
richardzetec Posted January 9, 2006 Share Posted January 9, 2006 3. There is a specialist glue remover that works very well, and don't be surprised but it's called 'sticky stuff remover', available at any good hardware stores like ours. I have personal experience as I accidently pieced a aerosol can of carpet glue in the shop and cleaned up with the said stuff. Evostick also do a cleaner. Richard Quote Link to comment Share on other sites More sharing options...
Blatman Posted January 9, 2006 Share Posted January 9, 2006 So if I'm over the noise I'm fooked ? Yep. They won't let you on if you fail the noise test, and they'll throw you off if you fail the drive by (if they have one). And you won't get a refund, 'cos you're supposed to turn up with a car that complies with the regs. Same for *every* track day with a posted noise limit... Quote Link to comment Share on other sites More sharing options...
slippy Posted January 9, 2006 Share Posted January 9, 2006 So I either gamble or spend £££'s on a repackable silencer Quote Link to comment Share on other sites More sharing options...
