oioi Posted July 20, 2005 Share Posted July 20, 2005 with that sort of failure it looks very lucky the engine did not go bang. are you going to take the head off and inspect to see if mr piston has been talking to mr valve? Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted July 20, 2005 Author Share Posted July 20, 2005 are you going to take the head off and inspect to see if mr piston has been talking to mr valve? Done a leak down test and looked in the ECU logs and it should be OK I am changing the big end bearings Quote Link to comment Share on other sites More sharing options...
Bananaman Posted July 20, 2005 Share Posted July 20, 2005 doesnt look over hardened to me, look soft centered ie only surface hardened. Keep us updated with how you get on, as I was considering one of these, but might go with my tried and tested albeit heavy alternative. Looks like it might be worth waiting untill a full product test has been carried out (good man Paul!!!! ...................... I think I'll stick with my Tractor gearbox for a while yet. Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted July 20, 2005 Author Share Posted July 20, 2005 I think I'll stick with my Tractor gearbox for a while yet That will be best with your tractor engine they go together so well Quote Link to comment Share on other sites More sharing options...
Matt Seabrook Posted July 20, 2005 Share Posted July 20, 2005 That will be best with your tractor engine they go together so well So what does that say about your engine then Paul if your broken gearbox matches you engine Just to add sorry to hear of your gear box Quote Link to comment Share on other sites More sharing options...
stu999 Posted July 20, 2005 Share Posted July 20, 2005 Why did it spin up to 10,000rpm? Quote Link to comment Share on other sites More sharing options...
YouMustBeJoking Posted July 20, 2005 Share Posted July 20, 2005 Doesn't the ecu have programmable rev limiting Quote Link to comment Share on other sites More sharing options...
S8ight Posted July 20, 2005 Share Posted July 20, 2005 Doesn't the ecu have programmable rev limiting wouldnt of reved from ignition, would of been when the shaft let go Quote Link to comment Share on other sites More sharing options...
YouMustBeJoking Posted July 20, 2005 Share Posted July 20, 2005 wouldnt of reved from ignition, would of been when the shaft let go How does that work then Quote Link to comment Share on other sites More sharing options...
Nick M Posted July 20, 2005 Share Posted July 20, 2005 An ECU rev-limiter can't cope with mechanically induced over-revs - an an input shaft snapping would have caused a sudden loss of load in the engine so it would have just spun up very quickly. I imagine the ECU complained loudly with lots of popping and banging, but there's not much it can do to slow down the inertia of the crank, pistons, flywheel, etc..... It's like changing down into first gear at 90mph - no rev-limiter is going to prevent the engine from over-revving in those circumstances. Quote Link to comment Share on other sites More sharing options...
YouMustBeJoking Posted July 20, 2005 Share Posted July 20, 2005 But this isn't mechanically induced over revving in the way that a change from a high to low gear would be. The sudden loss of load will allow the engine to accelerate rapidly, but cutting the spark will stop that instantly. No matter what load the engine is seeing, if the engine is disconnected from the wheels with no spark it cannot possibly accelerate. This is exactly the circumstance that a rev limiter is intended to protect against. Quote Link to comment Share on other sites More sharing options...
stu999 Posted July 20, 2005 Share Posted July 20, 2005 An ECU rev-limiter can't cope with mechanically induced over-revs - an an input shaft snapping would have caused a sudden loss of load in the engine so it would have just spun up very quickly. I imagine the ECU complained loudly with lots of popping and banging, but there's not much it can do to slow down the inertia of the crank, pistons, flywheel, etc..... It's like changing down into first gear at 90mph - no rev-limiter is going to prevent the engine from over-revving in those circumstances. Mmm. I must admit, I'm having truoble picturing this scenario in my minds eye. As I see it, a sudden loss of load will merely be like revving the engine with no load - and the rev limiter should stop it going any higher. I cannot see how the engine would rev any quicker/higher just because it was under load one second, and free revving the next... Changing into first from 90mph is not to be recommended however Quote Link to comment Share on other sites More sharing options...
steve_m Posted July 20, 2005 Share Posted July 20, 2005 But this isn't mechanically induced over revving in the way that a change from a high to low gear would be. The sudden loss of load will allow the engine to accelerate rapidly, but cutting the spark will stop that instantly. No matter what load the engine is seeing, if the engine is disconnected from the wheels with no spark it cannot possibly accelerate. This is exactly the circumstance that a rev limiter is intended to protect against. I would have thought that too but there was some debate (argument ) earlier this year regarding the Hayabusa engine. Apparantly with the clutch pulled in (you have to do this to start the engine) the rev limiter is lowered by 400 rpm, Suzuki claim this is to stop the engine over revving with no load as the ECU can't cut the spark fast/early enough. Maybe not having a flywheel helps this but in any case, I've tested it and it does limit a good 300-400 rpm lower. Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted July 20, 2005 Author Share Posted July 20, 2005 MBE logs show that the engine speed over the rev limiter was for a few hundred rpm over the limit and for only a second or so as you need to add up the readings I saw 8,500/9,000rpm on the Stack and the Ecu shows less Suden loss of load will let the engine spin faster for a second or so this was limited my the ECU cutting the spark and me liffting off Quote Link to comment Share on other sites More sharing options...
Nick M Posted July 20, 2005 Share Posted July 20, 2005 But this isn't mechanically induced over revving in the way that a change from a high to low gear would be. The sudden loss of load will allow the engine to accelerate rapidly, but cutting the spark will stop that instantly. No matter what load the engine is seeing, if the engine is disconnected from the wheels with no spark it cannot possibly accelerate. This is exactly the circumstance that a rev limiter is intended to protect against. It rather depends how quickly the sudden loss of load happens and how much inertia the rev-limiter is trying to limit. Note that I didn't say how long the situation would exist, just that since the limiter is electronic rather than mechanical it can't slow down the crank other than by influencing things which make the crank spin in the first place, i.e. fuel and spark. Quote Link to comment Share on other sites More sharing options...
