Westfieldman Posted July 16, 2005 Share Posted July 16, 2005 will post an update after I had a work with Mark at Elite I know what has broken but not why Mark knows its broken and I am waiting for a relpy so please wait and see Details and pictures to follow if MARK's OK with that. Quote Link to comment Share on other sites More sharing options...
greeny Posted July 16, 2005 Share Posted July 16, 2005 Any update yet? Is it clutch or gearbox? Hope you get it all sorted ASAP! Quote Link to comment Share on other sites More sharing options...
scott beeland Posted July 17, 2005 Share Posted July 17, 2005 Anything to do with the fact that it seemed a right tw** of a job to get reverse within a reasonable time frame?? Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted July 17, 2005 Author Share Posted July 17, 2005 Anything to do with the fact that it seemed a right tw** of a job to get reverse within a reasonable time frame?? No that was down to me getting use to it Quote Link to comment Share on other sites More sharing options...
Bazzer Posted July 17, 2005 Share Posted July 17, 2005 Bad news Paul !!! Hope its all sorted soon. Bazzer Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted July 17, 2005 Author Share Posted July 17, 2005 I have now spoken with Mark from Elite He is collecting the gearbox from work tomorrow from work [it's a little closer for him] and turning the repair around in a couple of days Now it looks like the engine spun up to 10,000rpm it still runs other than replacing the big end bearings and a leakdown test is there anything else that I can do to check it's all OK I will be resetting the chain tensioner as there self tighten too much at high rpm and wear the chain tensioner Quote Link to comment Share on other sites More sharing options...
Bazzer Posted July 17, 2005 Share Posted July 17, 2005 What happened ? Did it change down rather than Up ? Bazzer Quote Link to comment Share on other sites More sharing options...
scott beeland Posted July 17, 2005 Share Posted July 17, 2005 See I told you you should've stayed with the old box and put a VX in Quote Link to comment Share on other sites More sharing options...
mark.anson Posted July 17, 2005 Share Posted July 17, 2005 Blimey sounds expensive!!! Sorry to here youve broken it Paul. Puts my poxy misfire problem in the shade somewhat. The blat you gave me in the car at Curby was brief but bl**** impressive. Hope it gets fixed soon Mark Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted July 17, 2005 Author Share Posted July 17, 2005 you should've stayed with the old box and put a VX in And go slower than when I had my old engine [a Zetec] Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted July 19, 2005 Author Share Posted July 19, 2005 Pictures of he broken input shaft Basicaly the input shaft has been over hardened and snapped clean off [technical expleration promised via E-mail from Elite] Thet are making a new batch as the other 9 out of 10 are too hard as well so they are trying to get it back for Saturday evening or Sunday morning I have a track day Thursday 28th July Quote Link to comment Share on other sites More sharing options...
ACW Posted July 19, 2005 Share Posted July 19, 2005 doesnt look over hardened to me, look soft centered ie only surface hardened. Keep us updated with how you get on, as I was considering one of these, but might go with my tried and tested albeit heavy alternative. Quote Link to comment Share on other sites More sharing options...
Mike-SEiW Posted July 19, 2005 Share Posted July 19, 2005 It's supposed to be soft in the center. Possibly the residual stresses weren't correct. Not only do you want it hard (-ish), but you want the residual stresses to be right as well. It's easy to make mistakes. You'd be surprised how many companies that do heat treatment have no idea what we mean when we talk about residual stresses. (btw- I work for a company that make hardness and residual stress measurement equipment). Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted July 20, 2005 Author Share Posted July 20, 2005 From Elite Paul, After taking a look at your gearbox, we have found that the input shaft that broke was too hard. It was noted that the shaft had broken clean through which was unusual for it not to have any severe twisting. This caused us to investigate the materials properties. We found that the surface hardness was too hard thus making the core hardrer than required, which in turn created a brittle failure. We had taken your input shaft from a new batch of 10off shafts and foud that the whole of the batch were too hard, an error from the sub contract heat treatment company. We have now got to get them temper the other 9off shafts back to the correct hardness. :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: DAVE FENTON Elite Racing Transmissions e dfenton@eliteracingtransmissions.com t 01782 280136 f 01782 269913 Quote Link to comment Share on other sites More sharing options...
John Loudon - Sponsorship Liaison Posted July 20, 2005 Share Posted July 20, 2005 Bad luck Im almost glad I cant afford one now Hope all ends well. John Quote Link to comment Share on other sites More sharing options...
