Cobra 427 Build
And the Choccy Hobnobs
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
They only come out when the job is completed successfully :laugh:
I can’t remember hobnobs coming out
Only when the job is done ;)
Which job:bangshead:
21 hours ago, AdamR said:
Yeah sideways, like you are extending the hub axle. So if it steers, the line drawn isn't vertical.
Where would you mount the laser?
Centrally over the hub? Off any hub nut? Off the disc?
I am assuming centrally over the hub?
Anywhere as long as it points sideways and is attached to something that rotates when you turn the steering wheel. Gaffer taped to a wheel stud works for me!
  • 2 weeks later...
@AdamR
@corsechris
See attached photo
between 240mm on the jack and 300mm on the jack, so 60mm suspension travel we are seeing 14mm of deviation towards the rear of the car. The plot is 730mm from the hub
Opinions?
I make that about 1 degree. I’m no kind of authority, leave that to Adam, but FWIW, personally I’d want it less than that.
It’s far from horrendous though, which is excellent news. Great job considering how little you had to go on.
Thanks.
It will be interesting to see what Adam thinks.
Forgot to ask, how much of the available suspension movement was that 60mm, and if it wasn't all of it, which part of the travel?  If you cannot totally eliminate it, (or wish to) it's best to minimise it in bump, generally speaking.
Designing in specific amounts at specific ranges of travel is something I'd leave to the likes of Lotus myself! Way beyond my driving ability to tell the difference, or benefit from it.
It was a bit difficult as the car is not up to weight so hard to ascertain the position of the suspension when at kerbside weight. Basically it was wound up from full droop by about an inch, and the measurement started from that point.
The plot is taken whilst winding the hub up from the floor, so in bump.
It looked like the 60mm of travel was the total amount (or would be when a shock was connected), but again a little bit of a guess.
Cool. Lets see what Adam thinks.
Yes, come on @AdamR where are you ???
