MegaBoosta Posted March 24, 2020 Posted March 24, 2020 Westfield-branded, Bremsport Aluminium 4-piston calipers - M16 replacement for Westfield Aluminium uprights Braided hoses (clear coated) with stainless fittings to suit widetrack wishbones Siltech Racing drilled discs with integral 20-tooth trigger wheels, perfect for high-resolution traction and/or launch control £250 plus postage - SOLD Sierra rear calipers with handbrake cable Westfield-supplied braided hoses to suit widetrack wishbones (2311007) £75 plus postage - SOLD Brake pad sets to suit the above combination: Performance Friction 01 (front) + Performance Friction 97 (rear) - £80 plus postage - SOLD All used to great effect in sprints, but are simply staggering on a trackday - it would take something very serious to out-brake you!
NigelO Posted March 25, 2020 Posted March 25, 2020 I think I know the answer to these two questions (still on a steep learning curve...) As these are M16 replacements, does it mean they will also fit Sierra uprights? (I'm fairly sure the Sierra calipers are M16 - correct me if I'm wrong) Will they require a different master cylinder? I'm determined to lose some weight from somewhere - mostly my wallet....
Ian Kinder (Bagpuss) - Joint Peak District AO Posted March 25, 2020 Posted March 25, 2020 4 minutes ago, NigelO said: I think I know the answer to these two questions (still on a steep learning curve...) As these are M16 replacements, does it mean they will also fit Sierra uprights? (I'm fairly sure the Sierra calipers are M16 - correct me if I'm wrong) Will they require a different master cylinder? I'm determined to lose some weight from somewhere - mostly my wallet.... sorry @NigelO these only fit the Westfield upright which is based on the Cortina one, not Sierra. If you really want to dent your wallet buy some nice Siltech billet uprights and hubs, you can then fit these nice brakes!
NigelO Posted March 25, 2020 Posted March 25, 2020 12 minutes ago, Ian Kinder (Bagpuss) - Joint Peak District AO said: sorry @NigelO these only fit the Westfield upright which is based on the Cortina one, not Sierra. If you really want to dent your wallet buy some nice Siltech billet uprights and hubs, you can then fit these nice brakes! Thanks Ian - I thought so TBH, the chance of work (and salary) drying up over the next few months really means I should be raising money, not spending it,so I guess this is a lucky escape. However, at the risk of going off-topic, if the M16 caliper fits my uprights, why won't M16 replacement calipers fit?
Dave Eastwood (Gadgetman) - Club Chairman Posted March 25, 2020 Posted March 25, 2020 Yep, sorry, as Ian said, the Sierra didn’t use an M16 fit. There are Sierra fit callipers available from Willwood, or @Chris King - Webmaster and Joint North East AO has gone the whole hog, replacing his Sierra parts with stock Westfied and Cortina fit parts.
Kingster Posted March 25, 2020 Posted March 25, 2020 54 minutes ago, NigelO said: the M16 caliper fits my uprights Not Sierra uprights I’m afraid.
TAFKARM Posted March 25, 2020 Posted March 25, 2020 12 minutes ago, syman84 said: @RussH m16 replacment That’s why I was asking you yesterday about my uprights... Luckily, i‘ve already upgraded, I found some decent uprights and brake setup in the garage, attached to a megablade. 2
MegaBoosta Posted March 26, 2020 Author Posted March 26, 2020 Front set-up and Performance Friction pads now sold
