Bananaman Posted January 12, 2004 Share Posted January 12, 2004 Deleating SEX Icon After some slightly dubious surfing I now have a Ikon that keeps poping up everytime I boot my computer. I've deleated it & it keeps coming back so i traced the source to the windows file & tryed to deleat it but it says it's write protected. How the oops, i said a naughty word! do i get rid of it Andy P.S. As a seperate thing also related to my computer when ever I start my computer it always starts Windows Media Player which delays bootup by a couple of mins, any Ideas Quote Link to comment Share on other sites More sharing options...
adhawkins Posted January 12, 2004 Share Posted January 12, 2004 A file being write protected shouldn't stop you deleting it, it'll just give you a different prompt. What OS are you using? If it's NT / 2000 / XP Pro, make sure you're logged in as an account with Administrator rights. Then right click on the file, select properties, and turn of the 'write protected' check box. Then try deleting it. Not sure about the Media player thing. Is it in your Startup group? Andy Quote Link to comment Share on other sites More sharing options...
studbuckle Posted January 12, 2004 Share Posted January 12, 2004 There's lots of ways that this can be solved. My best advice is to do a google search for 'removing xxx' where xxx is the name of the sex icon you've had. As for media player starting up. does it play anything or just open up? Quote Link to comment Share on other sites More sharing options...
Bananaman Posted January 12, 2004 Author Share Posted January 12, 2004 As for media player starting up. does it play anything or just open up? Si It just opens the last file played, it does not play it unless you press the play button. f it's NT / 2000 / XP Pro, make sure you're logged in as an account with Administrator rights. Then right click on the file, select properties, and turn of the 'write protected' check box. XP Home. How do you log on as account with Administrator rights Andy Quote Link to comment Share on other sites More sharing options...
adhawkins Posted January 12, 2004 Share Posted January 12, 2004 f it's NT / 2000 / XP Pro, make sure you're logged in as an account with Administrator rights. Then right click on the file, select properties, and turn of the 'write protected' check box. XP Home. How do you log on as account with Administrator rights Andy On XP Home you don't need to (that's why it wasn't in the list of OSs that you need to) Andy Quote Link to comment Share on other sites More sharing options...
Bananaman Posted January 12, 2004 Author Share Posted January 12, 2004 Andy The Window that comes up says. Cannot Deleat File : Access Denied Make sure that the disk is not full or write protected & that the file is not currentley in use Andy Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted January 12, 2004 Share Posted January 12, 2004 Andy was the porn site worth it Quote Link to comment Share on other sites More sharing options...
adhawkins Posted January 12, 2004 Share Posted January 12, 2004 Cannot Deleat File : Access DeniedMake sure that the disk is not full or write protected & that the file is not currentley in use Andy Sounds like the program is running. Right click on the Task bar, and select 'Task manager'. Then select the Processes tab. Look in there for a process running with the same name as the file you're trying to delete. If it's running, select it and click 'End Process'. Then try to delete the file again. Andy Quote Link to comment Share on other sites More sharing options...
Bananaman Posted January 12, 2004 Author Share Posted January 12, 2004 Andy was the porn site worth it Paul Carn't remember I looked at that many. did you got to the Autosport show? Andy Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted January 12, 2004 Share Posted January 12, 2004 Andy was there much at the show [porn that is] Quote Link to comment Share on other sites More sharing options...
Bananaman Posted January 12, 2004 Author Share Posted January 12, 2004 If you like Lycra. Quote Link to comment Share on other sites More sharing options...
Martin Keene Posted January 12, 2004 Share Posted January 12, 2004 Andy I'll bet media player is in the "start up" bit on the start button. Quote Link to comment Share on other sites More sharing options...
adhawkins Posted January 12, 2004 Share Posted January 12, 2004 Not sure about the Media player thing. Is it in your Startup group? Ummm, I think I said that. Andy Quote Link to comment Share on other sites More sharing options...
Martin Keene Posted January 12, 2004 Share Posted January 12, 2004 DOH!!! Note to self: Must read *entire* thread before posting Must read *entire* thread before posting Must read *entire* thread before posting Must read *entire* thread before posting etc Quote Link to comment Share on other sites More sharing options...
7SE Posted January 12, 2004 Share Posted January 12, 2004 If you like Lycra. ...and silicone Quote Link to comment Share on other sites More sharing options...
