DRL's - where to place them!
You could do dimming with a slight adaption of @TableLeg method. Same wiring, but add a suitable(*) resistor across terminals 30 & 87 so when the sidelights come on and open the relay, the resistor gets put in series with the feed to the DRLs.
(* best worked out by experiment from an initial value calculated to give about 10% of rated LED current at a guess)
Finally installed my DRL's. Phillips Kit with control unit.
Made a bracket to sit under headlights and wired them in. Happy days.
Thank you everyone for replying the topic.
  • Like 6
Wow, looking good....
Noooooo.
I plugged my CTEK trickle charger in and my DRL stay on!!
Is it just a case of taking the fuse out to overcome this issue?
Have pm'd you....
