LiveTheDream84 Posted July 25, 2017 Posted July 25, 2017 Hi everyone, I have a pre-litigation Westfield and have been struggling with a strong fuel smell when in the garage for a couple of months now. I have now identified the leak around a screw on the fuel sender unit which I have removed and found the seal needs replacing, I believe the sender unit is a MTU115 moprod from a MK2 escort. Westfield, Demontweeks and Rally Design have all been unable to help me find a suitable seal as a replacement so I am hoping you will be able to point me in the right direction. Could any of you tell me whether a newer sender unit from westfield would be suitable or where I could obtain a replacement seal from? Cheers Andy Quote
Terryathome Posted July 25, 2017 Posted July 25, 2017 Get some material of Fleabay and make your own. Failing that some sealant that's OK with petrol will do the trick. Quote
LiveTheDream84 Posted July 25, 2017 Author Posted July 25, 2017 Thanks, I will give the sealant a try in the short term. Quote
Grizzlee Posted July 26, 2017 Posted July 26, 2017 17 hours ago, Terryathome said: Get some material of Fleabay and make your own. Failing that some sealant that's OK with petrol will do the trick. I have a large quantity of petrol resistant rubber, if you drop me a pm with your details I'll send you some when I get back to the UK at the weekend. if you can wait that long of course G. Quote
