Smokey’s Narrow rebuild
and a couple of radiator mounting brackets for the polo rad I'll be fitting.
As I'm going to fit a Polo rad in the winter upgrade season on my narrow, I'd be interested in the part number and details please! :t-up:
Here's your badge - welcome to the club!
http://img804.imageshack.us/img804/544/badged.gif
Keep up the good work on the rebuild, really going to enjoy watching! :t-up:
Cheers,
Scott
Am I allowed such a prestigious honer being the owner of both a wide and a narrow bodied car :blush:
Of course! PM sent!  :t-up:
Scott the rad you want is a Polo 1.3L one from GSF as I recall.
BTW During a recent shed clearout, I found the heavy old Escort rad lurking at the back of some dusty boxes and added it to a pile of metal bits for the scrappie to weigh in.
Out of interest they gave me nearly 22 quid scrap value for it...I'd tried to give it away and no one wanted it, got some beer money for it instead and no ebay winkers to deal with... :t-up:
Cheers mate, nice one!  Not sure if the old one is Escort or not, but it still has a radiator cap and overflow tube, two things I'd like to avoid.  Obviously the Polo one will need new mounts, so if Smokey got mounts from the factory, it will save me cack-handedly cobbling flat bar bits instead.  £22 for an old rad, good tip-off, project 50% funded! :t-up:
Out of interest they gave me nearly 22 quid scrap value for it...I'd tried to give it away and no one wanted it, got some beer money for it instead and no ebay winkers to deal with... <!--emo&:t-up:
Scott, the part number of the brackets are 2624007 they're the same ones as used on the wide body cars and on my mazda sdv.  They'll cost you the measly sum of £3.57 each which is a small price compared to having to make my own :)
Edit: I forgot to say thanks for my badge  :cool:
Cheers for that Smokey, much appreciated!
A small amount more progress made tonight.  :)
The car previously wasn't running a dual circuit braking system so I was planning on ditching the modified escort pedal box in favour of a floor mounted set-up.  I'd had a look at some of the bolt in options, but all were rather pricey and with my lofty height would also rather limit legroom.  In the end I went to Westfield for the parts they use on their wide body pedal boxes.  Slightly annoyingly they wouldn't sell me all the bits I need, only the bolt in parts, so a bit more fabrication will be needed to make the necessary brackets to weld to the chassis.
Half hour upside down in the footwell of the other car and I'd got the dimensions I needed from that so it was then off to the computer to draw it up,
you have far to much time on you're hands Mark ;)
and are they potatoes i can see growing on the floor panel  :p
Yeah, yeah ok so I haven't cleaned the car since I took it to the beach last weekend with the cambs lads  :p
In between doing the gardening and washing today, I managed to sneek in a couple more hours work on the car.  First job was to evict half the contents of the garage so I could make enough room to hoist the axle in.
A few minutes later, and with no blood drawn it's in and sat on some wheels.  I'm wishing at this point I got some springs at the same time I bought the shocks as the ground clearance is a bit low at the moment :D
It's a shame I'm going to have to take it all apart again for when I get the welding done and the chassis painting.
If its just for rolling chassis use, a couple of bits of box section drilled at the appropriate length in place of the shocks can help get you moving.
Have a look here on my build thread.
Lots of what you'll do I've been through too.
I did the pedle conversion too but the factory sold ne the complete kit including the brackets.
Chaz.
Thanks Chaz, that'll be useful.
I was hoping to buy all the pedal box parts from Westfield, but in much the same way as when I asked them for some suspension brackets it was explained to me that since the introduction of the sport turbo and their obtaining of type aproval they can't sell any parts to customers that have to be welded to a chassis :down: shame :down:
I wont bother asking them for some harness tubes to convert it to 4-point belts :D
First minor problem :bangshead:
Up until this morning I was under the impression that the ford english diff was available with 3 different pinion flange diameters and two different pcd's for the prop fixings to them.  87 and 92mm diameter flanges with a 70mm PCD and a 109mm diameter flange with 90mm pcd.
Looks like I have something very odd as mine is 92mm diameter but with a 76.5mm pcd (3") ??? I've searched google to see if it's something special but that's given no results ??? It doesn't worry me too much other than it may create problems for getting the propshaft made.
I was told by the previous owner that it's a It's a 3.9 ratio 10/39 cortina diff.
One question Mark - Who's going to get their head and torch down there to weld it?
The way its coming along, you'll be looking for a new project before long. :t-up:
