davew Posted November 7, 2002 Posted November 7, 2002 Just had fun fitting my first metalastic suspension bush, breaking a vice in the process. Anyone got any tips for when I buy a new vice and try and fit the rest!! Quote
Mitch Posted November 7, 2002 Posted November 7, 2002 Hi Dave, You'll have to get them fitted with a press (I broke my vice as well!, the garage down the road let me use their press for free. Better yet, use poly bushes as the metalastic ones probably won't last anyway. Mitch Quote
davew Posted November 7, 2002 Author Posted November 7, 2002 Hmm I think I may go the poly route, how are they fitted? Quote
markg Posted November 7, 2002 Posted November 7, 2002 each bush comes in 2 halves they push in from either side with a steel insert inside pictures on catmotorsport.co.uk Quote
Neil Purdie Posted November 7, 2002 Posted November 7, 2002 To carry on from markg - Using the supplied grease, push in both halves of the polly bush THEN push the steel sleeve through. If you put one half in with the sleeve fitted and then try to fit the other half, you get an air lock in the middle IYSWIM ( remove sleeve & back to step one ) A budget home vice should be OK Quote
markg Posted November 10, 2002 Posted November 10, 2002 i took the metalastic bushes back to westfield and traded them in for the polybushes the price difference is about £30 a set but you need to keep 2 metalastics for the rear wishbone where it bolts to the upright Quote
rowle1p Posted November 10, 2002 Posted November 10, 2002 I broke my vice also. Took the bushes and wishbones etc to Westfield and they fitted for FREE !. You can try putting a bolt through the bush and tightening a nut to pull the bush in but v fiddly. Just take back to the factory and they will fit for you. Or any garage with a press. Easy job. Phil Quote
Neil Purdie Posted November 11, 2002 Posted November 11, 2002 you need to keep 2 metalastics for the rear wishbone where it bolts to the upright Cat Motorsport hopefully supply the one for this, I have ordered all 18 bushes ( 16 for all the inboard wishbone bushes + 2 for the rear outboards ) Quote
megablade_andrew Posted November 11, 2002 Posted November 11, 2002 Talking to CAT over the phone they told me westfield would not take back new metalastic bushes in exchange for polys, but they would give me £1 each in exchange so it was my 18 bushes and £63, far from that of westfields £30 even if there are 2 more bushes. Bad CAT Quote
Mark Stanton Posted November 11, 2002 Posted November 11, 2002 Surely you wouldn't expect one company to exchange another companies goods If you purchase from Westfield then deal and speak with Westfield direct Similarly If you purchase from Cat then deal and speak with Cat Mark G didn't seem to have any problems i took the metalastic bushes back to westfield and traded them in for the polybushes the price difference is about £30 a set Quote
davew Posted November 11, 2002 Author Posted November 11, 2002 I have placed my order with cat and they should be receiving some of my hard earned very soon. 18 sets @ £4.50each + p&p Quote
furtive Posted November 11, 2002 Posted November 11, 2002 you need to keep 2 metalastics for the rear wishbone where it bolts to the upright Ahh. Do you? Quote
megablade_andrew Posted November 12, 2002 Posted November 12, 2002 Appologies to CAT motorsport, I misunderstood andy over the phone, actualy what he tried to tell me was westfield wouldnt take the bushes back for a refund. Andy very kindly called me back and offered to send on my bushes to westfield and refund me. Even after my cheekiness. Now that's service! Good kitty. Quote
Nick M Posted November 13, 2002 Posted November 13, 2002 but you need to keep 2 metalastics for the rear wishbone where it bolts to the upright Hmmm, I was wondering why too. Any ideas why these two specifically need to, supposedly, remain as metalistic bushes ? I've used poly bushes there with, apparently, no ill effects.... Quote
Blatman Posted November 13, 2002 Posted November 13, 2002 Yeah, me too. No problems yet, although it's on the sprint car, so mileage is VERY low (like, less than 5). ALL the mileage is done at 10/10ths though, with little regard for mechanical sympathy, especially when Blatgirl gets going Quote
