Cleggy's Spyder Rebuild 17 07 09
had today off to get back back on track with the project - so managed a good handful of hours with angle grinder and welder to hand
It was not a good day to be a neighbour of Cleggy  :devil:
Got a good chunk of the front framework fab'd up
Used the original sheet for the rear section which tucks under the new thicker front sheet (1.5mm) - I have made it all up so that I do not rivet into any box section
hoping to get most of the day off tomorrow as well - providing there are no issues  :suspect:
will start on the rear section as I have a few plans fully mulled over
not sure if the ali sheet will be strong enough without a brace (flat bar going diagonal) - would be nice to use a bead roller but I don't have access to one
what you reckon?
Hi Cleggy
Personally, I don't think 1.5mm will be strong enough for long life without deformation, and feel that a bit of bracing wouldn't go amiss.  However, I am betting someone will disagree with me and there will be a reply to this affect within 32 minutes, 47 seconds.  :laugh:
Seriously, I think you're doing a great job, far better than I could do.  Can't wait to see it at Stoneleigh as some point - this bl**dy thing has to go on the WSCC stand next year just for the epic tale.
captain is proabably right, the lowered floor on my westy is just aluminium and even with the seat mounting straps it has deformed.
Surely is an epic  :laugh:
Dom -  I think I have misled you my post does not read that clearly - I meant the foot well area for extra bracing not the lowered floor section (front alloy sheet is 1.5mm)
The rear part is the .9mm sheet and definitely needs bracing and I have already started putting diagonal flat bars into the lowered part - will be an update tonight
cheers  :t-up:
cool, it looks better this way and a tad lighter but again like captain said your doing a cracking job on this. i guess when your doing it on the fly changes like this are inevitable
i only posted as im not overly impressed with my lowered floor in the westy i like the idea to get the room but you see it sticking out under the body and the ali has always seemed flimsy where it drops down and i would worry that if i cluncked it it would just rip away. i think the braces that hold the seats go on could do with being a little thicker as they have deffo bent a little with the weight of me and the seat.
looking good mate. ;)
Thanks Tony
This one has come up for sale - if you fancy some fun - shame it is red though but looks good other than that
http://cgi.ebay.co.uk/porsche....iles_UK
U usual choice the red, but does look good in it. is it supposed to have a heated towel rail built in behind the seats?  :D  :p
Couldn't help noticing
QUOTE
...only weighs 500 kg
 :p  :D  :D  :D
Taxiiiii
500 kg - that's nothing, mine will weigh a lot more than that  :laugh:
the towel rail does not have any bracing by the look of it and I think all my electrics will be at the back - other than that I think it looks good
certainly sits well so they obviously overcome the wonky tub syndrome
I have seen pictures of some in other colours - nothing beats the silver although I did see a white one with a stripe that looked very cool
Mmmmmm Martini colours  :D  :t-up:
well then red spyder on ebay got to 18 bids at £6600 but did not sell as it did not meet the reserve  :oops:
been really swearing at my little 130amp SIP welder over the last few weeks - really have not been getting on very well - did all the usual checks and adjustments on the welder and ended up doubting my little bit of ability and the welder I was using
anyway finally thought about changing the tip for a new one and could not believe the difference - the old one was pretty manky but the wire seemed to feed through smooth enough so I was surprised it made such a difference
anyway I now will have to get the grinder out and re-visit some of my poorer attempts - all the weld will be covered with seem sealer so I am not too fussed as long as it is good n strong
pretty much all welded up now at the front foot well section
what do you guys think about the strength under the seat area - should I add more bracing - I don't wanna be doing a flinstones
your thoughts
Consider the wessy floor is ally with two very light lateral braces where the seat runners bolt to,  I recon its adaquate (  over engineered  ;) )   :t-up:
Unless your 7ft tall and weigh more than 350 Kg leave it alone   :D
you mean you have seen a picture of me
Thought I spotted you once .............
climing the post office tower   :p
seriously , it looks great  , now stop mucking around , get the thing  back together and get it road tested   :t-up:
