Cleggy's Spyder Rebuild 17 07 09
hopefully one day it is gonna be sumtin like these
Cleggy I think if my memory serves me correctly the fuel tank on mine was the original beetle item.
lewis
lewis
that's interesting - I have a dub specialist coming around today, I will ask him  :t-up:
I am still currently stripping things down - as you will see the main body is now ready to remove - just need to rustle up some m8s for a lift
I had a local Dub expert around on Saturday (thanks Fish) - i was pointed in the right direction and now have a big shopping list  :0
see the special modification to the fan housing to get it to fit under bonnet - they have hit it with a hammer  :D
and the air filter which was just sitting on top not actually doing anything
so the plan at the moment is a remote air filter and a fan housing of a Trekker which is apparently lower the the standard beetle one
added to the existing problem with the column - the current column has been shortened to fit - the problem is rather than cut a section out of the middle of the column, sleeve then weld, the builder just lopped a bit off the end which means that there is no spline in the column end
so if the securing clip came loose there would be b****r all to stop it from spinning around  :0
heat exchangers that provide heat to the front are being removed - not much point in having then on really
b****y hell Cleggy, Can't believe the builder would shorten the steering column like that, that's unbelievable. :0
yup that's what I though - shall be making a few calls today to try to source some parts
:bangshead:  :bangshead:  :bangshead:
blimey cleggy you have been a busy boy :p
Its certainly a mess under there.
give me a bell when you want a lift mate and ill come up
keep at it :D .
keep at it :D .
thanks Tony - will try to have a go next week in the evening - you free?
if the weathers good we can perhaps do the lift and a blat out - will I be able to hear you coming anymore
Are you officially living in the garage now mate?? :laugh:
Good luck with that project.
Dave
Hi Dave
Yeah most evenings see an hour or two - I have not been threatened yet by Julie to take a sleeping bag in there - although I am sure I cant be far away from the first onslaught of verbal missiles  :D
sealed it up last night cleggy and started it this morning and its sounds like a fiesta :down: so you wont hear it coming anymore.
Give me a bit of notice and ill sneak away from work a bit early, working up the smoke so shout when your ready. :t-up:
ps its the physical missiles you have to watch out for :D
:D  :D  :D  thanks m8
