gixermark Posted August 4, 2008 Posted August 4, 2008 be interetsing to see how much power a cat will absorb - in particular with things like Blades - as they ain't got that much to start with.. also may be an issue for temperatures... ? I think the guys in the RGB are doing some tests on this shortly.... Mark. Quote
Matt Seabrook Posted August 4, 2008 Posted August 4, 2008 Just how well do they think that a cat work on WOT in open loop. What a waste of time! Just to add it has no bearing on me as my cars is too old. Quote
cast iron Posted August 4, 2008 Posted August 4, 2008 I'll need a new helmet and overalls for the 2010 season by the look of it due to changes in the regs, that's before changes to the car... I thought it was 2009?? Quote
RobC Posted August 4, 2008 Posted August 4, 2008 Been doing some digging around for Cat advice ... seems if I want to get a Cat onboard I need to replace the silencer aswell... Hmmmm... Me thinks i might just wait and see what happens over the next few months with my engine change over before RR and see if I have some money left to replace things.. otherwise... TD's for me next year... Quote
Mark Stanton Posted August 4, 2008 Posted August 4, 2008 Not that I would condone cheating in any form but what I can see happening is one of the following: QUOTE Let's just say this cat rule is a load of the MSA cannot even test for a genuine cat fitment and I think quite a few cars will have "dummy cans" welded in that simply look like cats or Chassis plates will be re-stamped to ensure all chassis are pre 2000 My chassis is a 1989 and yet I could fit the latest spec engine without the need for a Cat every point so far noted has already been raised with the MSA .............. unfortunately the use of Cats is perceived as environmentally beneficial ............. yep its codswallop ........... but that's the ruling ............. its here to stay Think laterally I'm sure all you motorsport folks out there are used to interpretation of rules and regulations ........... this is just another one Quote
RobC Posted August 4, 2008 Posted August 4, 2008 no use to me... however £110 is better news... 5" long... I would have one if it worked or not... Like you say Mark.. thinking out of the box... Quote
fordy Posted August 5, 2008 Posted August 5, 2008 Is there a date on the chassis plate then - i dont recall seeing one ?? ill be checking tonight, as i think mine is a 1999 chassis - so will that mean i need a cat or not ? Quote
Andy @ Cat Posted August 5, 2008 Posted August 5, 2008 Is there a date on the chassis plate then - i dont recall seeing one ?? ill be checking tonight, as i think mine is a 1999 chassis - so will that mean i need a cat or not ? 1999 chassis means no cat Quote
John Loudon - Sponsorship Liaison Posted August 5, 2008 Posted August 5, 2008 1999 chassis for a car built in 2008 Quote
cidersurfer Posted August 5, 2008 Posted August 5, 2008 I'll need a new helmet and overalls for the 2010 season by the look of it due to changes in the regs, that's before changes to the car... I thought it was 2009?? I believe it's end of 2009... Quote
barney Posted August 5, 2008 Posted August 5, 2008 1999 chassis means no cat unless its a motorcycle engined car,where it will be compulsory... now clarified with msa...see below Quote
John Loudon - Sponsorship Liaison Posted August 5, 2008 Posted August 5, 2008 Ah - but you will make up for it with no road tax, insurance and MOT Quote
a4gom Posted August 5, 2008 Posted August 5, 2008 unless its a motorcycle engined car,where it will be compulsory... never read that bit? Quote
cast iron Posted August 5, 2008 Posted August 5, 2008 Oh the joys of a road going (no fuel break required) 1992 Westfield(no cat required) running a 16 valve 95KG 1600 engine of 2003 erra Quote
