Electronic Ignition
finally getting stuck in to the wiring (ok, so I'm slow...!)
On the Ford VR sensor as pictured in post #25 in this thread there are two wires - one blue with a yellow stripe and one blue with a red stripe (might not be red but I'm colour blind !). Anyone know which one is positive and which one negative, or does it even matter?
Rich
  • Replies 70
  • minisweeper
    27
  • RichP
    12
  • Hammy
    10
  • Blatman
    8
  • 2 weeks later...
It flippin' works! Started first time on the "safe" limphome mode - now need to hook up the ECU - all the wiring is done so should be ok
Question tho - the TPS I have requires a 5v supply from the megajolt ecu. I don't know if the V-Ref (pin 6) output from the ecu is 12v or 5v - anyone know? If it's 12v, what do I do? Don't want to fry it as soon as I plug it in.
Rich
Can't you just measure it with a multi meter?
Yap, realised that as soon as I wrote the post!   :durr:
If it's 12v I'm not sure what to do tho. I'll check first and worry later!
Edited to add for the reference of future readers: it's a 5v output.
All done and 3D seems to be working fine as well - chuffed to bits.
I have 2 wires not connected to anything that I'm not sure about:
Pin 4 - "Option" - Indicates ignition configuration 1 or 2. Connect to ground if only 1 used.
This is currently not connected to anything - does it matter or should I earth it? If I want to run 2 maps, what should it be connected to to trigger the second map?
Pin 13 - "Rev Lim" - Open circuit until active, then grounded.
This is currently not connected to anything - if I want the rev limiter to work, should I connect this to earth?
Many thanks
Rich
You can get a pretty standard on off switch from somewhere like maplins to connect to your option input and also to ground - therefore 'on' should be 1 and 'off' should be 2 or whatever.
Great feeling when it fires up first time isnt it! :)
Have you connected all your aux outputs up then?  I haven't bothered with mine.
Yep - couldn't believe it when it started - I was terrified that I'd have connected something wrong as I soldered and bound all the connections - would have been a right pain if I'd made a mistake somewhere!
No aux outputs yet - just a bunch of wires! I  have a set of 3 LED's to turn into shift lights when I get round to it.
The only thing I haven't checked is that the trigger wheel is correctly aligned so that in limp home mode it fires at 10 degrees btdc as I don't have a timing strobe, but is seems to run ok. Certainly much smoother, most of the popping and banging has gone on the over-run.
What did you hook your rev limiter output to - earth? I'd like that to work as I used to have one on the coil and the engine seems keen to rev past a point that I think is safe.
I dont have my rev limited connected - in the guide it mentioned something which was starting to sound complex (I think it needs an additional board?) and it has a soft limiter built in so I thought i'd just rely on that.  I have a shift light on my digital dash set at somewhere in the high 5's (i think) which I assume is suitable enough.
There is an output from the EDIS module for the rev counter I just connected mine to that and it worked !!
I used small LEDS ( actually an adapted LED torch) to give me a shift light.  One side of the led is connected to a 1k ohm resistor to an ignition switched positive the other side connected to a programmable output. By  hacking the inside of the torch I swapped some leds for green and red ones to give me a three stage shift light using 3 programmable outputs from the Mega jolt.
If you are not happy with that use a standard relay connected to a positive supply and the MJ output and switch the lamp of your choice.
I have not bothered with a rev limiter.
