Best N/A eninge is.....?
As stated in my previous thread I've decided to opt for a CEC with an N/A engine. Circa 210-220 h.p.
I'm thinking along the lines of an XE powered car.
Though is this the better engine to choose out of the other N/A engines available?
Wondered what you N/A Westfield owners are using and how does reliability/servcing/performance fair with your application?
All thoughts and opinions apreciated. :)
  • Replies 159
  • perksy
    13
  • Blatman
    11
  • Matt Seabrook
    11
  • stu999
    8
Right popcorn's on, pizza's on speed dial for later, and the beers chilling. Hunkers down in comfy chair and waits for it all to kick off.  :xmas:
Pour me a cold one Dave - i'll grab the pringles  :D  :D
:D    :oops:     :D
Not much on the Telly Tonight anyway
Fresh delivery of Stella chilling in the Fridge...
Ok, I'll start the ball rolling.
Is it a bird, is it a plane, nope it's a Superengine (aka Vauxhall XE). They are the bestest engine for a Westfield without a doubt
I can say that out load coz I've got my flameproof suit on :p:D
Tiggs
Yes    ;)
Nothing else comes close...
All engines can produce good power, some people swear by XE engines (I do because I have one), Zetec engines are tunable and the latest Duratec can pump out 300bhp with some money chucked at it.
Best go see a few, on your budget you may squeeze into Duratec territory, although I doubt it.
Might as well go XE powered :devil:
Would a stock XE produce 200bhp?
If yes or no, at what cost to get it there ???
I just may be biased.
Cosworth YB n/a.
93- 94mm bore gives massive valve area.
Nice short stroke giving lots of revs.
2.4 gives massive torque.
May be a bit heavy but no more than a VX.
It just needs some modern cams and pistons from someone prepared to give it time and effort.
If you want to follow the herd it has to be a duratec.
Maybe you are into S and M , then the S2000 engine, 240 bhp 9000 rpm straight out of the box.
On standard manifold or throttle bodies it makes very little difference
Regards.
Here We go     ;)
Fridge door opens, out comes the Stella...
:laugh:
Come on Perks, I'm thinking of building one, just need a guide thats all ;)
XE is getting dated now ;)
Duratec is the way forward to get a modern engine with 180hp on throttle bodies from a stock engine. and the weight you save will see you going past that XE boys anyway.
you know it makes sense
Ah Ians arrived,  :D I'll just pop another slab of Stella in the fridge, mmmm Pringles.  :D
Think 'The seer' is looking to buy secondhand   ???
So, Problem is unless 'The Seer' has a decent sized Budget He ain't going to be able to stretch to a Durabang engined car
Leaving Him no option but to buy a Westy with an 'old' engine that has Won countless Race's, Sprint's & Rally's around the country    :cool:      :devil:
XE is great but Duratec is better :laugh:
