neilwillis Posted March 8, 2005 Share Posted March 8, 2005 I did it for SVA, worked a treat. Quote Link to comment Share on other sites More sharing options...
perksy Posted March 8, 2005 Share Posted March 8, 2005 As with everything else there's choices. Doesn't matter which side you fit the ECU as the wiring is long enough for either side. I followed the factory's advice, which was to fit it on a hinged aluminium plate on the passenger side. Pro - can easily swing it down to get access to the ECU if you need to take it out; Con - gets in the way of the passenger footwell heater vent. Cheers, Rich ECU's and Water don't Mix very well. Keep it in the Dry Quote Link to comment Share on other sites More sharing options...
KerryS Posted March 9, 2005 Share Posted March 9, 2005 Con - gets in the way of the passenger footwell heater vent I took about 25mm off the width of the plate and mounted it as near to the outside as I could. With the heater now in place, the passenger vent points at the footwell OK. Kerry S Quote Link to comment Share on other sites More sharing options...
michaelc Posted March 9, 2005 Share Posted March 9, 2005 first time I've had anyone (who knows what a westfield is) look at it... ... I only know what a half built Westfield is ... Quote Link to comment Share on other sites More sharing options...
