nikos Posted April 5, 2024 Posted April 5, 2024 Hello everyone . i m NIkos from Athens Greece. i bought a westfield from toybox and a tranporter move it to bristol to take the ship to come in greece . the problem is that in bristol port cant turn it on . its 1700 crossflow carbs . maybe they have not turn on the fuel pump . or they flow it with fuel . is any chance to be someone close and take a look ?monday has the car to load it in the ship and the only way its to start up . thanks for all the help 2 Quote
Stuart Davis - Devon Cornwall & Somerset AO Posted April 5, 2024 Posted April 5, 2024 @Chris Broster - Bristol & Bath AO a long shot but is anyone around/nearby who might help? 1 Quote
Captain Colonial Posted April 5, 2024 Posted April 5, 2024 There might well be either a: FIA battery switch (big red key); or A fuel pump kill switch / anti-theft device;, or An inertial switch that got tripped by bouncing or shaking during transport - this cuts power to the fuel pump Does the engine crank over? Have you called Toybox? They might know something. Quote
nikos Posted April 5, 2024 Author Posted April 5, 2024 yes speak with toybox they told me that maybe its the fuel pump switch or maybe some damp in distributor cap that need a wipe . Quote
p k Posted April 5, 2024 Posted April 5, 2024 Nikos Do you know where the car is in Bristol docks, there are four different docks around Bristol 1 Quote
nikos Posted April 5, 2024 Author Posted April 5, 2024 2 hours ago, p k said: Nikos Do you know where the car is in Bristol docks, there are four different docks around Bristol just sent you a message thank youu Quote
nikos Posted April 5, 2024 Author Posted April 5, 2024 is any mechanic near in port i can pay to go ? Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted April 6, 2024 Posted April 6, 2024 9 hours ago, nikos said: is any mechanic near in port i can pay to go ? Have you got the post code for which port it's at? Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted April 6, 2024 Posted April 6, 2024 1 minute ago, Ian Kinder (Bagpuss) - Joint Peak District AO said: Have you got the post code for which port it's at? It's here- Royal Portbury Dock St George's road, Bristol BS207XL Quote
Rednop1 Posted April 6, 2024 Posted April 6, 2024 Have you spoken with the transporter ? Did he have any problems starting or is there any special tricks to getting it started ? 1 Quote
nikos Posted April 6, 2024 Author Posted April 6, 2024 nothing special just to find the fuel pump switch or to start it like carburetors cars press the accelerator a few times with choke out, this squirts fuel in to the engine and then start up Quote
Terry Everall Posted April 7, 2024 Posted April 7, 2024 Have you made any progress. Simple check of ignition required to see if you are getting a spark at the plugs. Is fuel pump running ? Quote
Stuart Posted April 7, 2024 Posted April 7, 2024 19 minutes ago, Terry Everall said: Have you made any progress. Simple check of ignition required to see if you are getting a spark at the plugs. Is fuel pump running ? He's in Greece and the car is in Bristol Terry...... 1 Quote
Stuart Davis - Devon Cornwall & Somerset AO Posted April 7, 2024 Posted April 7, 2024 @SXRORY @Paul Baker good to see you this morning. Any possibility of you, or anyone in your group who might be able to help out here? 1 Quote
nikos Posted April 7, 2024 Author Posted April 7, 2024 hello everyone . today had a chat the seller with a guy chris that will try to start up the car tomorrow . i hope to get start it. if anyone have some time to go for a look i will be glad . if i miss the boat then i have to find a westfield mechanic to take a look . the car have to load it in the boat until tuesday . Quote
