Jim cunliffe Posted December 11, 2023 Share Posted December 11, 2023 Help me out please ! Found these keys taped and cable tied to the loom in the ecu area along with what looks like a lock and a rotational adjuster switch (you can see from my post that I’m not a techie) Sport 250 2021 cheers Quote Link to comment Share on other sites More sharing options...
Jim cunliffe Posted December 11, 2023 Author Share Posted December 11, 2023 My sport 250 uses the SCS. Delta ecu. Quote Link to comment Share on other sites More sharing options...
dvd8n Posted December 11, 2023 Share Posted December 11, 2023 The SCS website says that the eco boost ECU uses a modified exchange ford loom. I suspect that the lock is part of that. D Quote Link to comment Share on other sites More sharing options...
Alan Cutler (Adge) - Dorset AO Posted December 11, 2023 Share Posted December 11, 2023 Nothing like that on my 250 loom with Ford ECU. Intriguing! Quote Link to comment Share on other sites More sharing options...
Jim cunliffe Posted December 12, 2023 Author Share Posted December 12, 2023 A better photo that shows 2 wires on the switch. Quote Link to comment Share on other sites More sharing options...
Gary Argent Posted December 12, 2023 Share Posted December 12, 2023 6 hours ago, Ian Kinder (Bagpuss) - Joint Peak District AO said: Where’s @Gary Argent? He must know. Sorry not to be more helpful but I've got the same lock and rotary switch on my loom (also running the SCS ECU) and I don't know what it does either! I'm following this thread with interest hoping to learn more.... FWIW mine was standard fit on the loom that arrived with the kit, and does not prevent me from starting the engine (although to be fair I've not tried twisting the key or moving the rotary). I don't have the starter button in my system, just the normal key ignition. Sorry I can't be more helpful! 1 Quote Link to comment Share on other sites More sharing options...
Jim cunliffe Posted December 13, 2023 Author Share Posted December 13, 2023 (edited) Thank you for the replies so far ! I’ve another one for good and great to look at ! Around the steering column area there is what looks like an OBD socket and to the left of it a socket that looks like is for a charger , the type you get on rechargeable items !! l wish Westfield had spent some time producing a manual !! Apologies for the poor photo, it’s dusty fin drilling the scuttle for electric mirror wires. Edited December 13, 2023 by Jim cunliffe Typo Quote Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted December 13, 2023 Share Posted December 13, 2023 AiM use a USB socket like that for the upload/download terminal for the dash, I have a trip panel like the ecu plate on the passengers side there, so I've mounted mine on that. I do seem to recall the Motorsport ecu originally supplied with the Ecoboost having an OBD port, so wouldn't surprise me if the SCS ecu had one too Quote Link to comment Share on other sites More sharing options...
Jim cunliffe Posted December 13, 2023 Author Share Posted December 13, 2023 When supplying kits for Westfield, their German distributor produced an EU6 compliant option. Westfield chose to use this wiring for all of their sales, including UK IVA vehicles. The key was for optional high boost map that wasn't homologated. The rotary switch was for variable traction control (only with additional wheel speed sensors fitted). Just got this back from SDS Delta ! 4 2 Quote Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted December 13, 2023 Share Posted December 13, 2023 Give me five or ten minutes and I'll move this into the FAQ section if nobody minds, it will come up again.... Quote Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted December 13, 2023 Share Posted December 13, 2023 OK, moved to the FAQ section. Have also hidden the incorrect guesses etc to keep it direct and to the facts. 1 1 Quote Link to comment Share on other sites More sharing options...
Alan Cutler (Adge) - Dorset AO Posted December 13, 2023 Share Posted December 13, 2023 2 hours ago, Jim cunliffe said: looks like an OBD socket and to the left of it a socket that looks like is for a charger Socket to left of OBD port looks the same as I have to connect laptop to the Aim dash (circled below). Connects direct into one of the two multi pin plugs on the back of the dash. Could be the same for you, unless you have another socket elsewhere for that? OBD port and Check Engine Light incorporated into PDM loom (circled red below) on Ford Racing ecu on my 250, presumably a feature on 250’s with that ecu. Moderators: Please delete/hide if deemed to be straying to far off topic! Quote Link to comment Share on other sites More sharing options...
Gary Argent Posted December 13, 2023 Share Posted December 13, 2023 5 hours ago, Jim cunliffe said: Thank you for the replies so far ! I’ve another one for good and great to look at ! Around the steering column area there is what looks like an OBD socket and to the left of it a socket that looks like is for a charger , the type you get on rechargeable items !! l wish Westfield had spent some time producing a manual !! Apologies for the poor photo, it’s dusty fin drilling the scuttle for electric mirror wires. That's definitely the port to connect a PC to the AiM dash, I've been using it on mine to configure the dash. Quote Link to comment Share on other sites More sharing options...
Jim cunliffe Posted December 13, 2023 Author Share Posted December 13, 2023 2 hours ago, Gary Argent said: That's definitely the port to connect a PC to the AiM dash, I've been using it on mine to configure the dash. Thanks Gary , love so much extra wiring under the dash ! Do you still have the wiring and connectors for the analogue instruments Quote Link to comment Share on other sites More sharing options...
Gary Argent Posted December 13, 2023 Share Posted December 13, 2023 6 hours ago, Jim cunliffe said: Thanks Gary , love so much extra wiring under the dash ! Do you still have the wiring and connectors for the analogue instruments Yep, had all that extra wiring on mine. Some I've cut off and / or used switched lives for other purposes, the rest I've just tied back. Still need to tidy it all up properly before I fit the scuttle... Quote Link to comment Share on other sites More sharing options...
