Cobra 427 Build
I dropped the tunnel panel off at the trimmer today and he seemed happy and keen to crack on with it, hopefully I should have it back by the weekend.
I have started to look at trimming around the door apertures and cill area now. I made up some fibreglass panels ages ago for this area. I will probably tweak one of the panels I made, but tonight I have bonded the first one in at the front of the passenger door.
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
Like the tunnel cover Gary. Always impressed by by your approach, keep up the good work.
Thanks 👍🏻
Fibreglass panels bonded into position around the passenger door aperture and cill. Once I have done both sides of the car I will then glass over all the joints to add some strength
Those shots bring back some memories from when I built my fake snake!  Those parts add a lot of stiffness to that section too.
Onward & upward!
Drivers side panels around the door bonded in and ready for glassing together.
Passenger side partially glassed together, bit more to do when I do the drivers side. It’s firmed up nicely now.
I had a day off work today so spent some time in the garage.
First off was to glass the panels together around the drivers door area.
Then I set about fitting some carpet. So passenger footwell vertical bulkhead panel, outer side panel and tunnel side panel are done, and I have made a start around the door area.
I finished the day off with a trip to the trimmer to collect my tunnel.
That tunnel has come out lovely , not that we would expect anything else.
Thanks, yes I am well chuffed with it
I understand why you would put it to a pro trimmer but did you fancy trying it yourself? You're obviously not one to outsource too many jobs and seem to tackle most things?
I wanted the stitch detail on the side and had no way of doing that myself
I spent an hour chasing an electrical gremlin this afternoon, hopefully that’s put to bed now.
Once that was out of the way I completed the carpet fitting around the door areas.
Then finished off by slotting the tunnel into position. It still needs fixing but that won’t take long.
I think it’s time to book the IVA test
The jobs list must be getting shorter!  Well Done.
Test booked and confirmed today, 19th March it is.....................best I write a list of what’s outstanding and get cracking 😳
