Cobra 427 Build
Are you all asleep or is nobody reading?
Nobody has spotted my deliberate mistake yet..........
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
:) just noticed the fog light the wrong way round.
3 minutes ago, KugaWestie said:
After IVA
Any particular reason? I've seen a few full bodied cars do this and never realised why. Does it not give the impression of an unfinished car?
Gold star for Steve ⭐️. Can’t believe someone wasn’t straight on it 😂
Yes I don’t want to knock a nice paint job whilst finishing the build working in a single garage.
Fair enough :yes:
I completed the rear lamps today by fitting the drivers side combined unit and also the number plate light. Nothing is wired in yet though.
Next was to fit the headlight bowls.
Followed by the headlights, again nothing wired in.
Great work and it’s always good to start adding and fitting parts. Looking at your rear end , those are a fair set of tail pipes in diameter, only noticed it when you see the other furniture added
keep up the good work
yes, without the the paint they do look pretty big, is that for complican reasons or you plan on keeping them?
These Cobra's look beautiful from every angle, The front of this is just stunning, Your doing well, Keep up the good work
Thanks Gary.
The plan is to reduce the size of the tailpipe tips as the are a bit ASBO really.
I intend to replace the two rear silencers with some larger oval ones as it is just too loud at present. When I do this I will sort the tips out at the same time. The exit pipe from the silencers to the tailpipe is 2.5”, but the tips are 4” at present!!
Today was time to play with a high value item (four figures 😳)
So first up was some setting out and chain drilling of the body.
Then a test of position with a steel rule to make sure I was in the right place for the upright to land on the chassis fixing area
First upright through
I repeated on the drivers side and then we were home and dry
Cast your mind back to when I adjusted the body to make the passenger door fit better. I was expecting to have to adjust a small area of the body to the screen where I forced the body into a new position. This proved to to be the case, so some local filling to make up levels so the body actually hits the rubber seal on the screen
£1000+ for a windscreen!!?
Yep.
All handmade, solid copper frame coated with chrome. Only one supplier makes them in the uk, they supply all the kit manufacturers, I had to wait over 12 months to get mine, so you are over a barrel unfortunately!
Brasscraft Gary?
