Cobra 427 Build
1 hour ago, Nic (NICO) - Shropshire and Mid-Wales AO said:
Silk purse, sows ear?
Keep up the good work Gary.
Thanks Nic
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
26 minutes ago, RussH said:
Nice work Gary - are those bonnet latches IVA friendly?
I hope so Russ, everyone seems to fit them and they pass, so should be ok
I finished fitting the bonnet locks tonight
Next up was to have a crack at fitting the gas struts on the bonnet. I Had a measure up a couple of weeks ago to decide what length I needed and then bought adjustable pressure ones as I had no idea what pressure would be needed.
I marked out the underside of the bonnet, and then got the drill out.
I then fitted Jacknuts into the holes, fitted the bonnet brackets and hung the gas struts in position.
I then marked out for the bottom fixing and fitted the bottom ball joint bolt.
Both sides done. Once in this position I started letting gas out in 1 second bursts alternating from side to side all the time to keep the pressure even.
The end result
1 hour ago, KugaWestie said:
The end result
feeling inspired for the Eleven front clam lift
Boot panel is next.
Sanded both sides and rough filler coat applied where needed
Underside of boot panel sanded and then etch primed.
There are a few imperfections that need some attention/filler, but it is much easier to see these now there is a coat on there.
Imperfections on the boot panel underside filled
Boot aperture etch and high build primed
Underside of boot filler sanded, etch and high build primed
Boot panel turned over and etch primed
Once etch primed I could see the imperfections, so out with the filler
In amongst waiting for stuff to dry, I started on a template for the boot base panel
I sanded the filler back this morning on the boot panel topside and finished off the primer process.
Its ready to be refitted now.
Coming along beautifully!
Can't wait to see the body all on together!
Thanks.
You say you can’t wait how do you think I feel?
Slow progress but rewarding!
Boot panel refitted. Next up gas struts.
Nice rear end 😍
Tonight was the night to tackle the boot struts.
Bottom brackets made and fitted, top brackets fitted to underside of boot panel, gas struts fitted and gas let out/adjusted down to allow movement. All good me thinks.
Then I tested the operation and closed the boot.
This operation was promptly followed by a severe bout of swearing to Tourette’s standard 🤬🤬🤬
After calming down I spent some time looking at the set up, and decided I needed to move the bottom brackets nearer to the front of the car.
The next test was much better
A good result in the end and I am very pleased with the smooth opening
