Cobra 427 Build
Whilst waiting for filler to dry, I fitted the boot seal
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
Before removing the bonnet to allow me to sand the filled section at the front of the bonnet, I decided to cut out the front of the bonnet scoop.
I need to fill the cut out gap between the inner and outer skins next
Whilst in the cutting mood, I had a go at one of the side vents using a diamond wheel in the Dremel.
The cut out needs sanding and tidying but I am pleased with how it came out
Some more filler applied to the bonnet scoop cut out tonight.
More to be done but the gaps are now filled totally. Sanding and shaping next!
  • 2 weeks later...
I have been steadily plugging away at the bonnet.
Scoop cut out filling completed
Etch primer
High build primer
It still needs sanding but I am going to leave it at it is for now
I'm so glad I only have 4 wheel arches and a nose cone to do on mine!!
The bonnet is close enough for now, so onto the bonnet aperture.
Sanded at 80 grit and then some filler applied where needed
Bonnet aperture has had two coats of etch primer this evening
Out if interest why etch primer on fibreglass?  Does it still etch?
As much as I would like to do the prep work by spraying, I simply do not have the set up, equipment, PPE, oven, dust free environment etc to be able to do this.
So I spoke to UPol technical department and I am using the products they recommended for hand application
UPol Acid #8 Etch Primer followed by UPol P88 High Build Nitrocellulose primer thinned 1:1
So I am following their advice
Thanks. Just I always assumed etch primer some how reacted with metal to key. Just didn’t know it would work with plastic too
Bonnet topside got etch primed and then high build primed this morning
Once this had dried I decided to tackle the bonnet latches/locks. I just need to order some fixing bolts for them and that will be another job complete.
Looks great
Silk purse, sows ear?
Keep up the good work Gary.
Nice work Gary - are those bonnet latches IVA friendly?
