Cobra 427 Build
And this is the end result. The lettering is actually white, the blue is just a protective coating that needs washing off when I eventually fit them.
I also purchased some centre spinners. These will be fitted after the IVA test
They are not perfect but they are a massive improvement and have come in at approximately half the cost of a set of new ones
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
They look awesome, great job done on the refurbishment
They look lovely Gary :yes:
Nice work, they'll really suit the car IMHO.
Back on the grp trail. A couple of brackets to secure the front of the nose section to the chassis
Laid up on some templates
Removed and curing ready for trimming
The good reading and pictures continue..  Thanks for the posts.
21 minutes ago, Trevturtle said:
The good reading and pictures continue..  Thanks the posts.
Cheers Trev 👍🏻
Ace work on the wheels Gary! Enjoying following your progress 👍
Boot hinges loosely fitted tonight, for a change it was a relatively straight forward job 😂
Working nicely
I also bonded my new front end brackets onto the inside of the body. Once these are cured I will glass over the body end, and then drill and tap a bolt into the chassis on the vertical side of the bracket..
Good progress Gary. Any plans to fit a gas strut to the bonnet or bootlid?
Thanks Mark.
Yes I plan to fit gas struts to both the bonnet and the boot eventually
I finished off the front bodywork mount brackets. Drilled tapped and bolted and also glassed onto the body
Another job today was the boot lock.
I can confirm that a 6’3” slightly lardy male can fit inside the boot, just!
I have been fretting about swinging the doors for a long time, but it is a job that I could put off no longer!
First up is the drivers door, so here it is just mocked up with clamps
Operation test
I am really pleased to have got it operational. Now everything needs positioning and fixing properly including trying to achieve a nice even gap around the door
Hinge action looks good.
When doing panel gaps on my last build, I followed advice from the kit manufacturer who told me to screw the panels together, fill and blend across the joins to get good lines then run a router along the gap line. Sounds brutal, but it works really well. I’ll see if I can find some pictures to show what I’m blathering on about.
