Cobra 427 Build
3 minutes ago, KugaWestie said:
This might sound mad, but the challenge was part of the appeal on this project
Not mad at all -I  can actually see the appeal 🤣
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
Nope, get it completely!
Youre probably just high on GRP resin
I am gonna miss my fix once the grp work is done 😂
  • 4 weeks later...
2 weeks summer holiday in Portugal done, back to work for a week and now back on the build.
I fitted my newly made fibreglass closing panel to the drivers side rear arch, and then glassed a few areas together.
Closer panel
Rear bulkhead at bottom
Rear bulkhead at top
Inside of rear arch looking at the new closer panel
Rear arch area
Pretty much finished the glassing on the drivers side rear arch area today.
Last section on the underside of the arch at the seat bulkhead
Closer panel on the underside of the car at the rear of the arch
Finally the back of the arch junction with the boot liner panel inside the boot area
I decided to have a look at the boot panel to see how it fitted.
Fettling needed!!
Drivers side
Passenger side
Front area
Bottom
Overall view
It pretty much didn’t fit anywhere
I fetched out the DA machine and put a 120 grit pad on it, and spent about an hour sanding.
The panel fits much better now. It still needs a bit of work but I think that it probably needs to have the hinges fitted next to see how it opens and closes once hung.
Drivers side
Passenger side
Front
The challenge continues, I admire your staying power Gary. Keep up the good work.
Keep it up @KugaWestie I’m just wondering if you now look like a massive pink GRP monster that breathes resin-fuelled flames. 😱
I am waiting for a few bits to arrive, so whilst waiting I took a look at the bonnet hinge arrangement.
The first job is to fix the kidney plates to the underside of the bonnet. There is a metal plate sandwiched into the grp of the bonnet, so I drilled and tapped this and temporarily bolted (nice bolts in transit) on the first plate.
Some more work on the bonnet hinge arrangement tonight
More work on the bonnet hinge today.
First job was to shape the box section to the shape of the nose. This involved a cardboard template and the sledgehammer :devil:
A few sharp blows, and it was done
With the box section curved to shape the next job was to make a grp housing for it. So I taped up the steel and the worktop, and then made something suitable in a top hat shape.
Once the housing had gone off, I removed the box section, cleaned it up and sprayed it.
