Cobra 427 Build
3 minutes ago, Captain Colonial said:
Well done Gary :t-up:
I hope you appreciate my restraint shown so far in not commenting about your escape from the carbon fibre dark side to the light and goodness of the chrome side...
...because that restraint has come to an end. :laugh:
MMMMMMM....SEXY, SEXY CHROME... :love:
I have been waiting for you to pop in :laugh::laugh:
There will be plenty of chrome on this car Scott, I am getting older now so time to join the polishing party
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
Very pleased to get it fired up to be honest as there were so many unknown quantities to bring together.
Home made loom
Rebuilt engine and the timing of it
123 distributor/ignition system
Fitech injection system
Great milestone to achieve Gary, well done. That V8 rumble is awesome!
Thanks. I thought the back wall of the garage was going to get blown away when it started :laugh:
Yay! Sounds great - nice job Gary!
Top work Gary :yes:
Great work and thanks for all the posts.. all good reading :yes:
Yep, a fascinating build thread. Great to read about alternative kits. Especially ones like this, that really put how sophisticated, by comparison, the Westfield is, into perspective.
Love that sound track, top work bud +1 :westy:
After a lot of faffing around trying to fill the cooling system up, I added a bleed point to the top hose by the thermostat housing. I drilled the centre out of some M10 studding and then tapped it with an M4 thread. I then fixed it into the silicone hose with two nuts, two washers and some sealant.
It worked a treat
I then capped it off with an M4 bolt which I put through a rubber grommet.
I need to try and do something a little neater to seal the bolt into the threaded rod, but I am happy that the idea worked!
I finished off by fitting the airhorns and compressor, they just need wiring in now
If you have a problem with the tee, I bought one of these from Merlin Motorsports to tee off from a hose for the Eleven and it's worked well.
Tee off
I bought the car up to temperature during the week and bled off the cooling system again. I think there is still a bit of air in it so will have another go when it is on the ground with the back end raised. When it was up to temperature it gave me the opportunity to fiddle around with the fan settings which is controlled by the Fitech.
I also checked all the smaller gauges, and they are all all working
I have also earthed the fuel tank
I dug out my air filter and dropped it on just to have a look
I have loosely connected up the steering rack to the front wheels as well.
So I think I am pretty much ready to start looking at the bodywork
Exciting times Gary!!
