Cobra 427 Build
I also started sorting out a tray for the battery.
Battery footprint marked out
Big block of wood cut to the same size as the battery
Sides bent up
Done
I need to work out how to mount it in the chassis next!
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
Bracket made and fitted. It needs to come back off for paint and also I need to sort a strap out to hold the battery in the tray
Nice fabricating @KugaWestie is that battery going to be an issue to get in and out when fully built?
I should be able to reach in through the bonnet to get at it and it will come out through the gap between the exhaust manifold and clutch master cylinder. I will know once I position the body for the first time though.
I decided to bolt (instead of weld) the mounting bracket to the footwell bulkhead with that very reason in mind!!
Like a man with a contingency plan
This afternoon has been very satisfying. I have completed the exhaust system, although it is only tacked up at present. I have decided to keep things simple and not have a crossover/x pipe. When I think about it, I have never heard a TVR that does not sound good, so hopefully this system will replicate that sound.
I did the more difficult side first which was the front section of pipe on the drivers side. It took me a while to get the pipe joints to an acceptable standard, but the patience paid off in the end.
The passenger side was much easier as I did not have to route around the starter motor and clutch slave cylinder
Here is the system on the car
Here is the complete system laid out in the back garden
I know my limits and do not intend to try and fully weld the system, so here is the pile of pipes I need to take to my friendly welder to sort it for me.
Once it is fully welded I can then look at one more set of hanging brackets/clamps.
I then need to decide whether to clean the whole system up and leave it like that or spray it with stove paint
I spent a little while this evening looking at the steering column and started to sort out mounts
The brackets are a good start. They will need to be strengthened with gussets etc once I am happy with the position
As it's stainless, give it a rub over with a Scotchbrite pad or the like to give it a nice matt sheen....then accept it'll discolour and get cacked up with use.
What colour scotchbrite pad would you recommend @corsechris ??
I’m guilty of the vacuum/Hoover transposition here, sorry. An abrasive pad....I’ll look at the ones I use and let you know :)
 I can tell you they are brown-ish but I can’t recall the brand.
ETA.
These: https://www.ebay.co.uk/itm/Mirka-Mirlon-Abrasive-Finishing-Pads-Scotch-Brite-Ultra-Very-Fine-Grey-Red-x-20/132408058156?epid=2256094761&hash=item1ed422a12c:g:iVkAAOSwBahU1Kex
The 'very fine' grade. They do a nice job on steel and aluminium.
Thanks @corsechris
Sorry Gary, been missing this and just been catching back up. With regards to the top hose on the rad. My TVR had an expansion vessel/ pressure cap/ highest point pot bolted to the chassis , which then cleared any air from the engine when running. You may have water/ air bleeding fun , unless I have missed something
 one here :
Some more work done on mounting the column.
Gussets added to the mounting brackets
There are another couple of mounting positions further down the column in the footwell. I managed to pick these up with some bolts through the top plate above the footwell and some spacers sandwiched in between.
I need to finally fix the fabricated brackets but may leave them just clamped in position for now until I offer the body up.
I also strapped the battery in
