Cobra 427 Build
Additional gussets welded into the rear of the tunnel area
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
I like a good gusset.....
:getmecoat:
Sprayed a few coats of red oxide over all the bare/welded metal
Underside of the chassis sprayed up tonight
Followed by a bead of tiger seal all around the perimeter of the floor pan extension and joint on the underside
Then I turned the chassis back over onto the axle stands and repeated the process on the topside. My rattle can just ran out before completing the spraying work so need to just finish this off once I have bought a new can
I can start building again soon :d
Excellent! Though the mods you’ve done should make a world of difference, interesting that it was done the way it was in the first place, when it would seem so much better to have done them your way.
Yes it is odd that the rails were not positioned like that in the first place really. It looks like it was meant to be like it is now IMHO
Someone had a good idea :t-up::p
I welded on the roll hoop mounting tubes this morning
Is a welder required for this kit Gary, or is it just because you're making your own improvements?
I think for the kit I have yes.
I have still got steering rack mounts to make/alter, as well as engine mounts to make. Also brake line hose termination points need welding on. I am sure there will be more stuff to weld as well
2.88 diff swapped today
3.54 diff sat in my boot, which will be dropped off in the next day or so for a full strip down, rebuild and derate so it lets go at the right amount of torque
  • 2 weeks later...
I had heard that the chassis sometimes fails IVA on the rear seat belt/harness top mount. The mounting position is in the corner of the "goalpost frame" you can see in the picture below. The IVA concern is that in a severe impact the frame could collapse forwards from the weight of the human travelling forwards.
The modification is to add some additional tubing to beef things up, so that was tonight's job.
I have also welded in some harnesses mounting points on the top corners of the "goalpost frame", you can see them in the above photo. The next step is to weld the threaded spacers/bosses on.
Good to see you're not just sitting in the sun!
Sounds like a sensible approach, particularly if it keeps you safe, and the IVA examiner happy.
Being nosey, what are the pair of large vertical tubes welded under the "goal post" for?
