Cobra 427 Build
Wow, that was fast!
  • Replies 1.7k
  • KugaWestie
    856
  • corsechris
    96
  • Dave Eastwood (Gadgetman)
    88
    57
Some more CAD work tonight, the template for the rear bulkhead carpet
Just now, Dave Eastwood (Gadgetman) - Club Secretary said:
Wow, that was fast!
I had already done the application and paid the test fee, so all I had to do was phone up and see what dates were available.
Rear bulkhead carpet fitted tonight. The CAD template worked a treat
Mind that paintwork 😉.
Looking really good, sure it will make good first impression on the examiner. Keep up the good work.
2 minutes ago, Adge Cutler- Dorset AO said:
it will make good fist impression on the examiner
Let's hope not!  😆
Looking amazing @KugaWestie, can't wait to see it in the flesh!
Thanks.
Its pretty stressful working close to the paintwork I have to say!
14 minutes ago, IainCameron said:
Let's hope not!  😆
Thanks.
Floor carpets are next, but they will be Velcro’d so hopefully I am finished with the contact adhesive 😷
I intend to fit a Cobra replica gear-lever once registered, but for now I need to do something for a gearknob.
This is one I had in the garage from an MX5 as the gearbox didn’t have a knob on it when I got it.
I decided to have a go at improving it. I put an M10 bolt into it and stuck it in the drill. The drill went into the vice and then I cable tied the trigger into the on position. An instant mini lathe 😂
I sanded it all down, and then applied a layer of filler over it.
Then sanded the filler down.
Then I applied primer, colour and 2K clearcoat.
It’s come out ok and much more presentable. Just needs a few days in the house to cure a bit more
Floor carpets templated/measured and cut to fit.
I then removed the floor carpets and glued some carpet onto the box sections.
I have also fitted my IVA fuel filler cap cover
IVA nut covers fitted to the door hinge plate bolts
Woah, you're going too fast.  For us armchair viewers this wonderful build is going to be over too quickly!
Too quick - I have been on it for over 3 years!!!!
