TableLeg Posted March 26, 2021 Posted March 26, 2021 5 hours ago, corsechris said: @GaryD1971 When Karl tried the new ECU on ours it took moments to put the map in, recalibrate the load sites then test it. I don’t recall if he used a map conversion tool or if it went straight in, but worst-case, you could just re-enter it manually. That said, I’d imagine transferring the map would be part of the service, but you could always ask the experts to confirm. ETA I can’t see why it would need any mapping after a swap, but again, ask the experts I'd agree Chris, I'm sure Emerald would be more than happy to transfer Gary's map to the upgraded ecu and I don't suspect it would take long at all to do. 1 Quote
corsechris Posted March 26, 2021 Posted March 26, 2021 Just checked the ECU on ours...41256 Doh! Probably explains why I didn’t upgrade it at the time - it would have been an entire new ECU at rather more than £180. Ho hum, will have to live with the pops and bangs I suppose. They don't happen often since the diff swap though. 2 Quote
